Jerry
Jerry Dork
3/30/14 4:25 p.m.
Motegi wheels with Yokohama S Drive tires 205/50-15 that were on my 2006 xB for sale. ~2-3yrs old with plenty of tread, includes the black tuner lugs. 4x100 bolt pattern. No scuffs or curb rash, I babied the car.
$400 Dayton OH. Or reasonable offer?
JohnRW1621
JohnRW1621 UltimaDork
3/30/14 4:37 p.m.
This website says that that an '06 xB would be 4x100 with a 54.1" hub.
It also says that the following are the same:
'90-'05 Miata
Mazda 323 and MX-3
MR2 Mk1 and Mk3
Toyota Corolla, Echo and some Celica
This should mean that with the hub spacers you have now, they would be a perfect fit for those.
If the buyer gets additional spacers, they will likely fit even more.
Good luck with the sale, they seem very nice.
M16ta
M16ta New Reader
3/30/14 5:21 p.m.
How wide are the wheels?
Edit: guessing they are 6.5" wide?
SlickDizzy
SlickDizzy PowerDork
3/30/14 5:54 p.m.
Offset?
Jerry
Jerry Dork
3/30/14 5:57 p.m.
I forgot I do have white plastic hub spacers that came with them, I do not know the offset or width right now. I bought them before I knew much more about wheels than "these look cool and fit my car".
I'll dig up the receipt and see if it's listed.
EDIT: 6.5" width, the tires were purchased 8/2011 (receipt from Tire Discounters) so basically driven on 2.5 summers. Would the offset be on the wheel somewhere? They were purchased before the tires and not sure I can find the receipt.
EDIT: Looks like 40 offset based on Pep Boys website where I first found them.
Knurled
Knurled PowerDork
3/30/14 6:23 p.m.
Are they hubcentric without centering rings?
I guess the gist is, I have a car that I'd want to put them on, but it has the 57mm pilots not 54mm, so I could only use them if they have removable centering rings, or aren't hubcentric to begin with.
Quantum #2 is nearing completion and I need to get it some shoes.
oldeskewltoy
oldeskewltoy Dork
3/30/14 6:31 p.m.
Too far... but they would do wonders supporting Grunt(my AE95)
Jerry
Jerry Dork
3/30/14 8:20 p.m.
In reply to Knurled:
I believe the answer is they were used with white plastic hubcentric rings to fit properly on the xB. So it sounds like they would work for what you need.
EDIT (again): this tech sheet says it has a 72.6 center bore. Motegi 116
vwcorvette
vwcorvette Dork
4/2/14 7:07 p.m.
Would you be willing to ship to Vermont? 05487?
Would look good on my Red 03 Mazda 2. 205s may be a bit too much rubber, but that wears down and needs replacing eventually!
Jerry
Jerry Dork
4/2/14 7:53 p.m.
In reply to vwcorvette:
Probably not. That would be some significant shipping hassle. They're actually sold pending $$ at the next rallycross in a few weeks anyway, but thanks.
beans
beans Dork
4/3/14 12:31 a.m.
Those bishes dual lug 4x114.3? Wouldn't mind having a second set for summer to tool around on so I don't annihilate these 2 year old Z1's DD'ing.
Knurled
Knurled PowerDork
5/2/14 8:44 p.m.
Epilogue: They fit the Quantum just fine without spacers, although the tire may rub the tie rod end in hard cornering.
Duke UltimaDork
5/4/14 10:41 a.m.
If those were 5x100, you'd have a PM. Rats.
MKX6DUUzh3zMMqfpGKrR47XgtYDnDiIfZS6HG7O8Z2G2SiPo7oXlOEXJ90rOmNNz
