Magicstick
Magicstick New Reader
6/12/14 6:20 p.m.
For sale is my 2001 Ford Escort ZX2, This is a fully track prepped car with many upgrades, yet smog legal for daily use. asking $3,800 The car runs very well with no mechanical issues what so ever. Everything in this car is in good working condition with no sign of problems. The engine rev up smoothy, and the transmission shifts in gear with easy, and brakes is sharp and firm. All suspension parts ride firm without any noise. All 4 New Yokohama S drive have 90% tread. Just went through a full service including timing belt, water pump, timing adjustment. It's a true turn key track car that you can drive on the road.
I had every intension to keep this car for a very long time, but plans have changed and need a bigger for work. Below is a list of mods on or off the car, please review in detail before you call. Thank you.
SUSPENSION: - Tokico Blue Shocks - Ground Control Coilovers - Hyperco Springs 350F/ 500R - Off the line Lower Tie bars front and rear - ZX tuner Adjustable rear Swaybar - Full Engery Suspension Bushing Kit - Marco Aluminum Front Strut Bars
PERFORMANCE: - Trubendz 2.25" Exhaust Magnaflow - B&M Short Shifter - K&N Typhoon CARB legal intake - Mocal Oil Cooler - JBA Shorty CARB legal header - Essliner Cam Gear - CWQ3 S/R Computer with piggyback superchip
BRAKES/ WHEELS/TIRES: - Light weight Black Cromo lug nuts - OEM 15" alloy wheels - New yokohama S Drive tires - Rolled Fenderwells - S/R Rear Disc Conversion using New Ford OEM parts. - S/S Front and Rear Corksport Brake lines - S/S goodridge Clutch Lines - Performance Drilled/ Slotted Rotors front and Rear - Hawk HP plus Pads font and rear.
INTERIOR: - 6Pt. Welded- in Roll Bar. - Sparco Speed Seat - Sparco seat rail - Sparco 4pt Harness - Keyless Pushbutton Ignition - Custom Oil Pressure/ Oil Temp/ Water Temp Gauges. - Sparco Pedals - Sparco Steering wheel - Sparco quick release hub
WEIGHT DEDUCTION: - Removed Soung Deadening - Light weight racing Battery Conversion - ZX Tuner OEM fiberglass hood (painted to match body) - VIS full carbon trunk lid - A/C Delete with manual Rack Conversion - Power steering delete.
OTHER: - ZX tuner Black Housing headlights - 2003 Front Bumper with Grill inserts - 2000 S/R valve cover
ADDITIONAL PARTS WITH SALE: - Misc Hyperco/ Eibach Springs for coilovers - Bilstein custom treaded body race front coilovers - Spherical race rear upper strut mounts - Replacement cusco bearing cups - Rear Camber Bolts - Cam Alignment tool/pin - Centerforce clutch - Fidanza lightweight flywheel - Hawk HPS font and rear pads
Open to possible trade on truck or SUV. please send offer and photos. thanks. Call: 626-376-0078, NO TEXT PLEASE
tjbell
tjbell New Reader
6/13/14 1:56 p.m.
this should be posted in the open classified section as it is over 2014$ but ncie ride and glws
Ciqd0JqOuL9iSpgIzqfrnrLnJAr88IaStpNxb7EUg466etWSLf9FSRxbQfIm89a8
