Rumnhammer
Rumnhammer Reader
11/14/16 6:39 p.m.
These are all the parts you need to handle fuel and timing when you turbocharge a Mazda Miata. When you turbocharge a car you need to add fuel and retard the timing. These pieces allow you to do this with the stock ecu and stock fuel injectors. All parts are in perfect working order and let me run 8psi of boost in a 94 miata with stock ecu and injectors. They are a pierburg auxiliary High pressure fuel pump this lets you run more fuel pressure so your stock injectors act like bigger ones. It mounts inline near the fuel filter. it goes for $550 when combined with the fmu from BEGI. The next is a BEGI rising rate fuel pressure regulator this sends a restriction to raise the fuel pressure it is already tuned for 8 psi and includes all the fittings etc to go right onto a miata. These sell for $250 by itself from BEGI, or $550 combined with the pierburg. the next item is a Bipes ACU this allows you to run more timing so your bottom end stays sharpe, then senses airflow and air temp to retard the timing under boost, so you don't get detonation. it is already tuned and set up for a 1.8 miata running 14 degrees of timing. it can also be set to work on a 1.6 as well. It goes for $225 from BEGI The other two items in this package are a Autometer narrowband AFR gauge and a electronic fuel pressure gauge with sending unit to monitor the fuel pressure and to keep tabs on how rich or lean you are going based on fuel pressure. They both go for about $80 new. I'm selling this as a total package for $400 The other item in the pics is a Blitz electronic boost controller, it allows you to raise your boost electronically from inside the car and you can have 2 presets a high and a low I ran the low at 6 psi and the high at 8psi. This is being sold separate from the rest for $150 If you want to buy the boost controller I will add it to the package for $100 so you can buy the entire package with the boost controller for $500 if you were to buy all these items separately you would be close to $1000. Everything works perfectly and is in excellent condition I'm selling them because I got a standalone ecu that does all things that all these items did. I would like to sell this as a package but if you only need a single item, pm me and I'll consider breaking it up. Although this is set up for a miata, it will really work on any car with a return fuel line as far as the fmu is concerned. The Bipes ACU will work on any car with a AFM or a MAF great opportunity to add a turbo safely as this takes care of fuel and timing if you still need to use the stock ecu like a OBD II car. I take money orders and paypal
[URL=http://s27.photobucket.com/user/Rumnhammer/media/pierburg%20pump_zps3acjpifr.jpg.html][/URL]
[URL=http://s27.photobucket.com/user/Rumnhammer/media/bell%20fmu_zpsooayctd4.jpg.html][/URL]
[URL=http://s27.photobucket.com/user/Rumnhammer/media/bipes%20ACU_zps2xwqmxpp.jpg.html][/URL]
[URL=http://s27.photobucket.com/user/Rumnhammer/media/fuel%20pressure%20gauge_zpsj30av7gp.jpg.html][/URL]
[URL=http://s27.photobucket.com/user/Rumnhammer/media/AFR%20meter_zpsz3hqzjrc.jpg.html][/URL]
[URL=http://s27.photobucket.com/user/Rumnhammer/media/blitz%20ebc_zpsvjddhtoa.jpg.html][/URL]
[URL=http://s27.photobucket.com/user/Rumnhammer/media/total%20package_zpszuvgnyz2.jpg.html][/URL]
I may have some wiggle room on the price when adding the boost controller.
please reply to me via pm or to my email Rumnhammer@aol.com
If you are interested in buying single items the pricing is as follows fuel pump $100
rising rate regulator $75
Bipes ACU $100
fuel pressure gauge $10
AFR gauge $20
boost controller is still $150
Rumnhammer
Rumnhammer Reader
11/18/16 3:57 p.m.
In reply to Rumnhammer:
Boost controller sold Bipes is pending.
Rumnhammer
Rumnhammer Reader
11/21/16 5:25 p.m.
All items sold.
z5sIlZGS1VArKR4QAf4NPxCXllwlKVmGMWAVm1RGU7xiV2kMDQSYzdWJaanfl6Jh
