BigD
BigD Reader
9/10/18 4:59 p.m.
For the record though about VEMS - it might be old and unglamorous but it's really tough to beat, even at higher pricepoints. It's one of the reasons I resisted changing for so long - because short of something like the Infinity 7 or a Motec M150, there's really nothing out there that wouldn't be a backwards step in one way or another (for various reasons but one of the biggest ones being the dashboard - many guys with standalones I see don't even have a fuel level gauge on their dash or a relatively straightforward way of adding one). Even though I'm leaving the club, I do wish them well and I hope this new platform they're working on makes them a modern contender.
BigD
BigD Reader
9/15/18 6:33 p.m.
Need new tires, good time to go bigger...
WHAT ARE YOU DOING??? Finally the car works perfectly, is tuned perfectly, drives perfectly... so obviously the best thing to do is to rip it all out. Sucks how easy things are to ruin after they were built. It's a good thing this car has developed my imagination as a coping mechanism because while the end product is exciting, it still starts with some BIG steps back.
Mezzanine
Mezzanine Dork
9/16/18 4:34 p.m.
It's not a car, it's an engineering exercise. <- that's what I tell myself when I have big setbacks. Self inflicted or otherwise.
Keep us posted on the progress with these changes!
BigD
BigD Reader
9/17/18 1:41 p.m.
Yeah, and up until the events of this year, I started accepting the idea that I may just be a builder, that the car would never really see any action. And I would have been fine with that. It truly is primarily a learning exercise. Pretty much everything I've done to this car is the first time I've done it. So the fact that it all works and works as well as it does is, well, frankly mind blowing.
Will do! The parts which will remove the need for the fusebox should be here Wednesday.
Mezzanine
Mezzanine Dork
9/17/18 3:22 p.m.
PDM? You tease! Which one are you going with? I was sorely tempted to go this route but I just couldn't justify the cost in a casual use mostly street car.
BigD
BigD Reader
9/17/18 3:59 p.m.
You'll see :) Well, put it this way, if I could afford Motec, I wouldn't be here talking to any of you plebs. I'd be at the airport 2nd floor looking down through the glass at you people.
I have been drooling at the idea for a long time since I was introduced to it, since it is such a perfect and obvious solution for a racecar. But I couldn't justify the cost, even the non-Motec version. But now redoing the whole dash wiring, it made me cringe having to continue mcgyvering the E30 fusebox so I decided I need to go solid state at the same time. All the gauges are coming out, all switches and buttons (incl blinker/light and wiper stalks), except for the fire handle and two rotary knobs for boost and TC. The rest will be replaced by one keypad and the AEM dash.
BigD
BigD Reader
9/18/18 5:12 p.m.
Awwyeah!
BigD
BigD Reader
9/23/18 8:48 p.m.
Making good progress. Got all the ECU wires labeled, same with the relevant chassis side stuff except for the pickup pumps and fuel level, just need to isolate and clean that up, and the fuse box can come out. It's a bit nuts how much this project is simplifying the wiring. The first wiring pic is after I already removed the traction control, that was an additional big pile of wire.
Starting to brainstorm a pretty 3D panel to show off the new hardware and mount things solidly.
BigD
BigD Reader
9/24/18 2:30 p.m.
The final goodies to complete my wiring madness have arrived. Going to wire all the grounds to that bus bar instead of ring terminals and the MSEL main relay instead of a kill switch.
BigD
BigD Reader
9/25/18 8:42 p.m.
One of the last remants of 80s BMWness is gone
Almost there! Now to design a panel to mount the new hardware and start crimping pins.
BigD
BigD Reader
9/29/18 8:33 p.m.
Alu mandrel bends, plate, thin plywood and balsa... what does this have to do with a dashboard? Not sure yet but should be fun!
BigD
BigD Reader
9/29/18 8:34 p.m.
Starting to look like something... Hope to get the hardware mounted and dash prepped or almost prepped to go for carbon work.
BigD
BigD Reader
10/7/18 6:18 p.m.
Making progress, a lot more work than I envisioned, definitely need a plasma cutter. But so far so good. Platform for the new hardware is ready, moving on to the dashboard, hopefully get it done this week and off to get the carbon treatment
My new outers arrived for the front rims to turn them into 11s for the 315s
Was sent this pic of my car from one of the events this year. Such an amazing year of milestones for it that it's still hard to believe but I'm actually looking forward to driving it next year and making more progress rather than wondering if next year is the year I actually get to drive it as I meant to
BigD
BigD Reader
10/8/18 6:24 p.m.
Getting close!
Nader
Nader New Reader
10/8/18 10:19 p.m.
Good lord!  Every few months I check in, and this car gets crazier and crazier.  At some point in the near future when I next check in, I expect this thing to have antigravity propulsion and landing skids.
BigD
BigD Reader
10/8/18 10:28 p.m.
I actually thought about putting a flux capacitor in with this project but at 700 bucks they're either high off their ass or it actually works but they priced it so no one would mess with the space/time continuum
https://www.amazon.com/DIAMOND-SELECT-TOYS-Back-Future/dp/B001M5PTQM
BigD
BigD Reader
10/9/18 9:36 p.m.
Home stretch, once the right wall is done, a bit of glazing putty, some finish sanding and off to get a skin.
rustomatic
rustomatic New Reader
10/9/18 10:39 p.m.
There is a future for you in bespoke hand dryers--Dyson has nothing on you when it comes to design.  That said, if you could find a more appealing process than hand blowing, your work may find a purpose in Hollywood, where pointless and expensive come together like magic (profit!).  Perhaps the key is your design and fab presented as a face dryer that will not negate the great benefits of various surgical procedures or man-makeup.
In all seriousness, I am a huge fan of the car and your fabricational tangents.  Rock on with your crazy!
BigD
BigD Reader
10/10/18 7:08 a.m.
I like it! I'll talk to Borg Warner at PRI, maybe they can supply me some titanium EFR wheels to make titanium Borg Warner hand dryers out of! They'll come complete with anti-lag mode for the important man on the go.
Haha, thanks a lot!
BigD
BigD Reader
10/25/18 3:03 p.m.
Getting there. Going to dig into the rear bodywork this weekend and hopefully get it all filled, sanded and primed and paint next week. It's getting too cold to paint so hopefully I can get enough heat in there consistently for a few days. Cleaned up my garage too, I can actually see the floor and my workbench again! Dash is progressing nicely too and it's turning out quite sexual.
BigD
BigD Reader
10/27/18 9:15 p.m.
I need Adderall. A lot of it.
BigD
BigD Reader
11/7/18 11:23 a.m.
Feels like I'm over the hump, hopefully things are downhill from here, in a good way. Less than a month to PRI
My name is Darth Vader. I am an extra-terrestrial from the planet Vulcan!
Mezzanine
Mezzanine Dork
11/7/18 4:40 p.m.
Is the car going to be at PRI? I'm having some strong book-a-ticket-and-go-last-minute thoughts. I'd love a chance to see this thing and meet you in person!
BigD
BigD Reader
11/7/18 4:48 p.m.
Yessir, at the ARE drysump booth. Kinda crazy that my hooptie will have pretty prime placement, their booth is one of the most prominent, they're next to ATI, at the corridor where all the traffic goes between the halls, by the machining gear.
BigD
BigD Reader
11/8/18 10:39 p.m.
Precious is home! Need to be patient to install it, gotta clean the car up after painting and finish the wiring. SOON
0Jl5wZ2PmL96ufDOw2k6P4lRWBLxLXPNEK0jJmxzBBw12ZZPdXRpmCEkYxQcYrN3
