OK, so I got the axles attached to the diff, and then secured to the hubs... other than fluids, the back end is done! So, I figured it's time to get started on the rest of the drive train, as in gearbox and engine. So, dragged them out to the front of the garage/workshop, and separated them. Actually, the throwout bearing looks good, and the clutch plate has plenty of meat left... no matter, I've got brand new heavy duty clutch components waiting to go in. Then I spent the better part of two afternoons stripping the ancillaries off the motor in preparation for exchanging it for a rebuilt unit. Everything was pretty solidly attached, what with years of sitting idle outside. Used lots of PB Blaster, but got it pretty much stripped. I'm getting a Sam Halkias built motor... I could go into the details of what he offers, but suffice to say it should be in the 135-140hp range, built with all new or refreshed components and then run before delivery. I'll also most likely opt for a lightened flywheel and fan delete.
Now, my question to you TR6 gurus and internet experts out there... how far should I go with this build, and where should the money best be spent? For example, the basic "hot street" motor Sam offers is .020 over, 9.5 compression (regular gas) and runs Richard Good's GP2 cam. I'll be running the standard 2 Strombergs, but with a header and fairly open exhaust. I could opt for a bit more compression, as I'm probably going to run non-ethanol fuel (90 octane) or premium (93 oct.) if necessary.
The big decision... if I go for more, I'm considering either a) 1.55 ratio roller rockers or b) cam bearings and the GP3 cam, Either option will add about $800 to the build. With the 1.55 roller rockers I'll reduce friction, gain lift and maybe 10% more HP. The cam bearings by themselves won't add horsepower, but add durability, and would be necessary for the higher lift cam and I could go up to 1.65 ratio lifters. I talked to Richard Good, and he felt that the stock cam and even his GP2 cam should be safe without the cam bearings, but also felt that they did offer a margin of safety and longevity. The 1.55 rockers add some stress (pressure) to the cam, but, again,"should be" OK. Obviously BOTH would be better still, but that's a lot of money. Or, maybe I'm chasing the wrong rabbit, and should pursue power/longevity/drivability via other means.
So, internet oracles, speak your wisdom at me...
