The stock intake tube will not work. In order for it to clear the S10 hood, it'll interfere with the upper outlet on the water pump. I need to make more room for the intake elbow. I could go to a double pass radiator with the inlet and outlet both on the passenger side, but at this point, I would prefer this project just nickel and dime me, not Franklin and McKinley me.
Saturday, I figured out a route that should work with the intake, I just do not have all the hose I need. I'll wait until what I have on order shows up, then get more if I need to.
It should tuck just fine between the engine and fan shroud. Just in case, I'll make sure it is secured to the shroud, so it doesn't risk getting chewed up by the idler pulley.
I'll need to cut the intake tube a bit to keep it from contacting the radiator and the fan shroud.
The next choice is whether or not to relocate the battery. It'd make the intake path pretty easy. However, it's also nice to stick to the stock battery tray, and there is enough going on on the driver side that I don't want it there. I could put it in or under the bed, but then would need a cutoff switch to take it to the drag strip. I think the path forward is to get another 90 degree bend, some couplers, and a cone filter, and run it pack over the passenger side fender liner. Heat will be an issue, so at the least, it should get a heat shield between it and the header. Better would be if I can build an enclosure, and maybe run a tube to pick up cool air from some openings below the battery tray. If it weren't for the complications of trying to route through the radiator and transmission lines, I'd even consider putting the intake under the battery tray.
Between work last week, and yesterday's thinking, my brain was about done. I decided to swap out the rear axle, since that should be more brawn than brains. I tried to salvage the parking brake cables in case they could be adapted on the disc brake rear, but the drums would not come loose, so bolt cutter it was. Then went to work disconnecting other parts.
Took more time than planned, but it eventually came out. I also yanked the setback plates, since the truck will need a new driveshaft anyway. That'll raise the rear ride height 3/8", which would've pretty much leveled out the truck before. Now, with the coilovers and the LQ4, I'll have to see. I am worried I went with too stiff of a spring, and even at the lowest setting, the front may sit a bit high. I did leave the 4 degree shims in, but will recheck and switch to whatever is needed to get the proper driveshaft angle after everything is together.
Out with the old and weak:
In with the somewhat less old and somewhat less weak:
Getting the new axle in was almost easier than removing the old one.
I still need to tighten a few bolts, like the ones for the rear shackles, and need to check others. The soft brake line bolted right up, I hope I didn't damage it too much pinching it off. If so, it should not be too expensive to replace. I need to figure out what combination of 1st and 2nd gen S10 parking brake hardware is needed to get it to work properly, but that is not an ultra high priority now.
Took some measurements for the driveshaft length before packing up for the day, now I just need to do a little research of how driveshaft shops want to measure to and from. If I can find a reputable shop nearby, I'll try and get an order put in soon, and there'll be one more thing to check off the list. For now, I'm pretty sore and just want to relax for a bit.
