Cleverfrog
Cleverfrog Reader
5/26/17 8:42 a.m.
For the longest time I have found myself wanting a kart. A very good friend of mine had one growing up and that was the fix for the want. A couple years ago now we got together and made a nice little course in his yard and did a timed lap race. We tried to continue the tradition last year however, we ended up kersploding the engine in his kart trying to tune it up. Somehow, the governor didn't get reattached and the rod decided it didn't want to live anymore. Since then, I have been rebuilding that engine. Now though, I desired to build my own. So, for months and months I searched the interwebz hunting and scrounging forums and other sites looking, hoping to find the frame I longed to build. At long last I had found one. The glorious Tony Kart frame. Being well versed in Autodesk has been a blessing, as I did not find a dimensional draw, no, I found a complete 3d model made in solidworks. It took me a bit to break apart the assembly and detail the frame but, I did it. Next step was to get materials to start this build. Through my work I was able to get great pricing on a few sticks of 1" DOM steel tube for the structure. So, now I had my material but, no way to bend it. I toyed around with the idea of just using a torch and a barrel or something. Even packing with sand and using a cheap bender. I ended up driving up to Chicago to Eastwood. There, I picked up their heavy duty manual mandrel tube bender. Brought that home and put some expanding anchors into the garage concrete to mount it. This way I can unbolt it and park a car in there without worrying about puncturing a tire. Once that was all set up I decided to just dive right into making the frame tubes. First couple pieces were really just figuring out the bender but, I ended up getting the frame bent up properly. Bender was super easy to use and replicate bends. Next item on the list was tube notching. Picked up the cheapest notcher I could manage from harbor freight. Would not recommend for angles past 25-30*. I got most of the notches pretty dead on other than a couple. Past 25ish degrees the notcher doesn't have enough room to fit the material. Anyways, with that laid out I started tacking and welding. That is pretty much where this post leaves off. I've done much reading on engines and such has led me to want either a flathead briggs, like my friend's, or a clone. I say these because of cost for one, the flathead is ruthlessly simple and the clone because of multitude of parts and mods available. Anywho, let me know what you think and if you have any experiences suggestions. All are welcome. Oh, some pics too of the build here!
Us standing/working on our friends kart giving it a tune up.
IMG_0482
IMG_0485
The aftermath of last years debacle.
IMAG0118
And now onto progress shots of my work. The bender.
IMAG0173
The notcher.
IMAG0208
After bending them getting them laid out in the rough locations.
IMAG0182
Starting to tack and weld. (I'm not a welder, I just have one so I can pretend)
IMAG0207
Well, let me know what you guys think.
Indy-Guy
Indy-Guy Dork
5/26/17 9:47 a.m.
Sounds like fun, but the pics aren't working...
Cleverfrog
Cleverfrog Reader
5/26/17 10:23 a.m.
Ahh, I always have this problem with google photos.... Fixed?
mazdeuce
mazdeuce MegaDork
5/26/17 10:31 a.m.
I like where this is going. Seems like a logical first project for someone who wants to learn to bend and notch tube. I may know someone who wants to do that.....
Cleverfrog
Cleverfrog Reader
5/30/17 10:33 a.m.
Great memorial day weekend progress. I am now to the point of purchase parts for the most part. Frame is perfect but, I have very little experience doing any fab work really. It is a great start like Mazdeuce said. I definitely wouldn't recommend the harbor freight notcher to anyone. For all the trouble I had using it, I would've rather paid more for a more functional unit. Budget cart though so. Need axle mounts, hub mounts and motor mounts. After that everything is purchasable. Wheels, tires, seat, engine etc. We will see how fast my wife let's me finish this. Especially since I have another build going on. That one though is considerably more expensive.
IMAG0218
ManhattanM (fka NY535iManual)
ManhattanM (fka NY535iManual) Reader
5/30/17 11:01 a.m.
Very cool! I am functionally computer illiterate. Do you think someone without your autodesk/software skills could pull off a build like this? Asking for a friend...
RossD
RossD UltimaDork
5/30/17 12:27 p.m.
Nice. I'm certainly going to follow along since I think I need to build a cyclekart soon and that's just a glorified go kart with a 'vintage' body. (And the pictures are showing up just fine!)
java230
java230 SuperDork
5/30/17 12:30 p.m.
Oh very nice! I too want a kart.... I have a 13hp honda motor just sitting under my work bench asking for a torque converter and a frame....
Following along
5/30/17 2:16 p.m.
I've got a 650 Yami hanging around .....
fanfoy
fanfoy Dork
5/30/17 3:08 p.m.
About the HF notcher. If you want to keep it working for more than a few notches, make sure to lubricate the drilling shaft and make sure it's clean. The bronze bushing in which it's mounted are really cheap and get used up really fast if you're not careful. Resulting in a loose fit and crappy notches.
Ask me how I know.
But they do the job if you are careful.
TOQcN5LyqLDBifHxuL35Z0TMRcrd30jZXnRvMPbnrn5dTt7WXmoxmXYDrvwVno7T
