10/17/18 7:59 a.m.
The Saab 96 project came with no keys.  I plucked four wires out of the back and wired two to a toggle switch to lite the coil and two to a starter button.  It works, BUT, the wires get pretty warm.  Granted I was using a jumper wire that was a bit smaller than the factory wiring; if I used larger wire diameter do you see this at a problem?
Thanks, Dan
RossD
RossD MegaDork
10/17/18 8:00 a.m.
Smaller wires are problems, larger wires are solutions....usually.
10/17/18 9:41 a.m.
Thanks.  I put the momentary button behind the cigarette light, I'm good as long as no one wants to smoke in the car while driving.
rustyvw
rustyvw Dork
10/17/18 5:28 p.m.
Smaller wire has more resistance, which creates more heat.
JFxg9gmwxQ3BxlRUkt1LFa0FKz0qwfTKnGmTjmQ8eWk9iZSY6fPkNdkkeBketbXX
