shawnmaster
shawnmaster None
2/17/13 11:26 a.m.
Hi I have a few questions about how it will all fit to work into my project with an LS1 swap into my 69 camino. I bought an LS1/4l60e transmission complete with all accessories beltdriven and computers. Has it all. Now my el camino already has a 350/700r4 inside it. Shouldn’t the mounts line up for everything since it’s the same size engine and transmission including length and driveshaft fit?
Also need to know anything about relocating belt driven parts to make this as easy as possible.
Thank you for your help.
-shawn h.
shawnmower87@gmail.com
oldtin
oldtin UltraDork
2/17/13 11:42 a.m.
Start measuring - everything. It's likely to be close in dimensions, but I wouldn't bet on a drop in fit. LS engines were a clean sheet design, so there isn't all that much in common with the 350 that's in there now.
Oh yeah, pictures man pictures.
shawnmaster
shawnmaster New Reader
2/17/13 11:58 a.m.
i will definitely add pictures this week. im just concerned with the belt driven units to relocate them and other parts that i may need by suggestion.
jmc14
jmc14 Reader
2/17/13 12:15 p.m.
The engine mounts are different. There are adapters that will bolt to the LS and allow it to bolt into the old style engine mounts. I'm not sure about the trans.
Street and Performance will be able to answer all of your questions and supply parts. I'm sure that there are other suppliers too. Have fun.
MichaelYount
MichaelYount Reader
2/17/13 12:54 p.m.
http://www.yellowbullet.com/forum/showthread.php?t=456907
http://ls1tech.com/forums/conversions-hybrids/885933-69-chevelle-ls1-conversion-need-help.html
http://www.chevelles.com/forums/showthread.php?t=341797
Will
Will Dork
2/17/13 5:08 p.m.
Street & Performance has how-to articles on putting LS1s in anything. There's a link at this page that shows how to put one in a 70 Chevelle...should be pretty much the same as your El Camino.
S&P also sells all kinds of parts to help with the swap.
noddaz
noddaz HalfDork
2/17/13 8:12 p.m.
One of the Vanilla magazines just covered this...
In case that can't be found, here is something from 2009.
ls chevelle
heyguy
heyguy New Reader
3/4/13 12:13 a.m.
this post help you deal with all problem of 4l60e Transmission Symptoms Of The Car When 4l60e Transmission Not Working Properly read it here http://www.4l60etransmission.org/category/perfectly/
reviews trail running shoes buy running shoes
DmtWzpIn7nsGFJaNiRGCMIr1hI54d32A2nj9K6JyjHKmrehnzkdowTap2iOJDGfX
