Dhill
None
9/29/19 6:15 p.m.
Hello everybody and thanks for checking out my build thread. I'm currently building a 323i for trackdays but used the grms $2000 challenge as a guideline to stay within budget. I do have a question. I want to do a stud conversion, do I need record the cost of the studs in the excel sheet?
Dhill
New Reader
9/29/19 7:35 p.m.
found a lot of sludge in the engine
Dhill
New Reader
9/29/19 8:03 p.m.
replaced oil filter housing gasket, oil pan gasket, spark plugs, and valve cover gasket
Stampie
UltimaDork
9/29/19 8:05 p.m.
Studs would be exempt so I think third tap no budget hit.
Studs are exempt but you can put it in the budget with an exempt note
Dhill
New Reader
9/29/19 8:33 p.m.
Thanks for the reply. I will try and have them installed before the event
Dhill
New Reader
9/30/19 1:41 p.m.
engine in its new home. Also installed condor speed shop solid engine and trans mount.
Dhill
New Reader
9/30/19 1:46 p.m.
installed garagistic solid chassis mounted short shifter and dssr selector rod.
Dhill
New Reader
9/30/19 1:49 p.m.
All that's left is bleed brakes, bleed clutch, adjust the coilovers, and take it for shake down. Then I can focus on stripping the interior for some weight reduction.
Dhill
New Reader
9/30/19 3:46 p.m.
I have a quick question,
I bought toyo proxes r888 off eBay for $800 and it came with some no-name rims. Tires and rims were never used. I priced the tires on tire rack for $843.76. How can I calculate the fair market price for the no-name rims?
In reply to Dhill :
I would probably look for similar-style wheels of the same size and width on ebay that look equivalently no-name-ish, and go from there.
I thought I had seen serious sludge, but that makes everything I have seen before look like a clean engine.
Dhill
New Reader
9/30/19 4:13 p.m.
In reply to slowbird :
Will do thanks. The only thing I'm wondering is do I really need to find the fair market price for the rims since it came with the tires.
Dhill
New Reader
9/30/19 4:15 p.m.
In reply to TurnerX19 :
Lol it was bad. Didn't have time to properly remove the sludge because of the time crunch. I removed what I could.
Dhill
New Reader
9/30/19 4:16 p.m.
She is alive ladies and gentlemen!!
In reply to Dhill :
When in doubt, if you have a picture of the wheels, folks here will be able to give you an estimated FMV based on how nice/crappy they look.
Dhill
New Reader
9/30/19 4:24 p.m.
Lol I will post the picture
Dhill
New Reader
9/30/19 4:29 p.m.
That 's the best picture I have, but i have proof of paypal transaction.
Thinking about it some more, given that you have the receipt, and everything is basically "new" I think it'd be fair to say you paid $400 for the tires and $400 for the wheels, so if you're just using one or the other on the car, you can probably justify that as a $400 budget entry. Others may have a different opinion.
On the other hand, if you actually sell the rims, then you'd recoup that amount towards your $800 purchase and the remainder would go into the budget.
Dhill
New Reader
9/30/19 5:39 p.m.
remember the tires are not part of the budget
In reply to Dhill :
Oh, that's right. I forgot.
Then in that case...I'm completely at a loss for how to account for the wheels. You could say the tires were worth $800, being never used, and the wheels were free...but someone could call you out on it. If it was me, I would pro-rate the tires at something like $600 as "technically not new, but never used, brand-name tires" value, and say the wheels were $200, which works out to $50 each, which sounds plausible for pre-owned no-name wheels of questionable origin. So then I'd put the $200 wheels in the budget, and the $600 tires would go in as exempt, just so they're documented...and then hope for the best.
slowbird said:
In reply to Dhill :
Pretty much my thoughts on wheel value. Ive scored sets for 100 ($25 each), but never nice ones.
Stampie
UltimaDork
9/30/19 6:53 p.m.
Nice rims I don't play over $200. Not nice not over $100. Dude has a meth habit I'm offering $50 at most.
