GTXVette
GTXVette SuperDork
8/8/18 5:14 a.m.
I can use this van if I replace the trans, IT'S A 93 DODGE RAM 350 /W 360 MAGNUM ENG. I Want to put in an OD Trans because of the 4.10 rear.
1. MOST SIMPLE SWAP
2.NO OR MINIMAL ELECTRICS.
FOUND SOME PIECES OF THE BAND IN THE PAN, WILL BE MORE SIMPLE TO REPLACE.  SO WHAT YEAR AND WHAT FROM,
Thanks, john
minivan_racer
minivan_racer UberDork
8/8/18 5:58 a.m.
Auto?  Pretty sure it should be a 4 spd already.
GTXVette
GTXVette SuperDork
8/8/18 9:27 a.m.
nope, 3, no indication of otherwise. 3/4 ton van, so I see it not having OD,   BUT i WANT ONE
fwingo
fwingo New Reader
8/8/18 9:36 a.m.
buzzboy
buzzboy Reader
8/8/18 9:43 a.m.
You should be able to find an A518 or 46RH that bolts right up and gives you 0.69 OD.
GTXVette
GTXVette SuperDork
8/8/18 10:25 a.m.
In reply to fwingo :
nice but too expensive for someone else's truck
Thanks B B that iS what I'M LOOKING FOR
Dusterbd13
Dusterbd13 MegaDork
8/8/18 11:24 a.m.
If you go over to www.forabodiesonly.com, theres a ton of writeup for exactly this.
t8Mlw8CLLeTjRWAqJlsp3QlWHg7YJ4ECRZF4DCbipCy8wLpKkB6zdCRTTRjADbnf
