Fitzauto
Fitzauto Dork
6/8/18 5:13 p.m.
I need quite a few -6 fittings for my new fuel system. I was going to buy through JEGS, but dang, the price adds up quick with these suckers. Any place to buy them cheaper? or am I just gonna have to suck it up?
z31maniac
z31maniac MegaDork
6/8/18 5:27 p.m.
No help, but just saw your post in the SCCA AutoX Facebook group.
In reality, I think you just have to suck it up.
Fitzauto
Fitzauto Dork
6/8/18 5:32 p.m.
In reply to z31maniac :
Thats what Im afraid of. Being jobless right now puts a damper on spending for stuff like that sad
44Dwarf
44Dwarf UberDork
6/8/18 5:52 p.m.
Check surplus aircraft places!  JIC and AN are the same.
Datsun310Guy
Datsun310Guy UltimaDork
6/8/18 7:26 p.m.
We sell JIC fittings.  Which ones do you need?
gearheadmb
gearheadmb SuperDork
6/8/18 8:46 p.m.
Summit usually has quite a few in their clearance section on the website.
Dusterbd13
Dusterbd13 MegaDork
6/8/18 8:59 p.m.
Ive bought lots from ebay. The REALLY cheap ones aren't the greatest, but do the job. A dollar more buys a lot on these on ebay.
AwesomeAuto
AwesomeAuto New Reader
6/8/18 9:41 p.m.
I typically use ICT Billet or Fasster from ebay.
93gsxturbo
93gsxturbo SuperDork
6/9/18 8:26 a.m.
BITD the Jegs and Summit house brand were significantly crappier and harder to assemble than the name brand ones.  Whats the cost of a fuel fire?  A few months in the burn ward?  Are those chinesium fittings really a savings?
Fitzauto
Fitzauto Dork
6/9/18 9:09 a.m.
In reply to 93gsxturbo :
Good to know. Ill probably go with Earls then
RX8driver
RX8driver Reader
6/9/18 9:15 a.m.
Try checking at local tractor, truck or industrial supply places for prices on getting them to make up hoses for you with crimped JIC fittings.
Dusterbd13
Dusterbd13 MegaDork
6/9/18 9:25 a.m.
Since we'r talking about an fittings, what fitting would one use for a nitrous supply line? I have one that one end was cut off of and want to repair for the challenge car.
Patrick
Patrick MegaDork
6/9/18 10:19 a.m.
You don’t.  You throw it out and get a new line because we’re talking many hundreds of pounds of pressure
Knurled.
Knurled. MegaDork
6/9/18 10:43 a.m.
In reply to Patrick :
Why?  People make their own AN brake lines all the time and those see as much or more pressure.  Nitrous is about 900psi, right?
IIRC common nitrous lines are -3 or -4.  -4 is the same thread as a GM fuel pressure test port and -3 will allow a 1/8NPT to start to thread in, if you want something easy to find to gauge what you have.
Patrick
Patrick MegaDork
6/9/18 1:54 p.m.
I guess, but i’m not doing it.  I made power steering lines once out of braided high pressure teflon line with stainless fittings, that was possibly the most miserable experience of my life short of losing loved ones.  I guess new pre made lines are cheap enough to not bother for me, and I’d rather trust a factory crimped end with the job
Datsun310Guy
6/9/18 2:01 p.m.
We have 8-10 different crimpers at work for hydraulic and industrial hose.  We can crimp a 6” chemical hose or use our high volume bullet crimper for fast work.
Every one in the building hates field crimp or sometimes called reusable fittings with a passion.
Suprf1y
Suprf1y PowerDork
6/9/18 3:02 p.m.
I used to recommend JIC as a cheaper alternative to AN here but gave up because everybody  kept telling me I didn't know what I as talking about.
Nylon poly tube works for Nitrous. Cheap and easy.
Dusterbd13
Dusterbd13 MegaDork
6/9/18 3:17 p.m.
Can you break it down to what i need to tell the hydraulic shop? This sounds ideal.....
Knurled.
Knurled. MegaDork
6/9/18 4:15 p.m.
Power steering is a special level of hell.  The pressures are very high AND they need large diameter hose like -6 or -8.  Normally you have low pressure large lines or high pressure small lines.
Most AN hose is not rated for power steering, the stuff that is, isn't DIYable.
93gsxturbo
6/9/18 4:31 p.m.
Not doable at home but your local hose shop should be able to put a new end on it.  Probably won't be pretty anodized but should work fine.
Fitzauto
Fitzauto Dork
6/9/18 4:43 p.m.
In reply to Suprf1y :
What size JIC corresponds with -6an? If its cheaper Im all for it.
EvanB
EvanB MegaDork
6/9/18 9:40 p.m.
It's the same, -6 jic (3/8" ) will interchange with -6 an.
impulsive
impulsive Reader
6/10/18 12:31 a.m.
I recall getting some Earls fittings that were from chingchangistan.
One of which was a metric to AN adapter I used from clutch master cyl & it ended up leaking because the inverted flare was machined too deep and the threads bottomed out before the flares could seat.
Fitzauto
Fitzauto Dork
6/10/18 1:27 a.m.
In reply to impulsive :
Hm. What brand isnt made in china then?
Suprf1y
Suprf1y PowerDork
6/10/18 5:57 a.m.
In reply to Dusterbd13 :
High pressure nylon tubing and (I think) brass fittings with ferrules - the shop will knbow what to use based on the pressure rating. The tubing and fittings are both rated for 1000-1200 psi with a 4-1 (4000-4800 psi) safety factor. Worked fine for me.
3pwYpCt3mqtcPD8EBAgKLcd18jvw3dd6zE9fNkNluwvL0r4VgqjSl7JcuQSwVNvr
