neon4891
neon4891 SuperDork
7/7/11 10:04 a.m.
What are the methods for removing random locking lugnuts from cars at the junkyard? I have had to pass on nice wheels because of this before. Any ideas?
EvanB
EvanB SuperDork
7/7/11 10:07 a.m.
I have heard to hammer a 12pt socket over the nut and crank it off. When I had to remove the locking lug nuts from a car in my garage that trick did absolutely nothing but YMMV.
Turboeric
Turboeric New Reader
7/7/11 10:24 a.m.
Cold chisel and BFH. Use the chisel to make a notch in the edge of the lock nut, then use the chisel in the notch to rotate the nut off. I've seen a tow truck driver do that and get the nut off faster than it would have taken me to dig out the "key" and do it.
mndsm
mndsm SuperDork
7/7/11 10:35 a.m.
Turboeric wrote: Cold chisel and BFH. Use the chisel to make a notch in the edge of the lock nut, then use the chisel in the notch to rotate the nut off. I've seen a tow truck driver do that and get the nut off faster than it would have taken me to dig out the "key" and do it.
This. For funzies, you can use a can of compressed air, flip it upside down and freeze the nut too.
neon4891
neon4891 SuperDork
7/7/11 10:45 a.m.
Compressed air, time to raid the supply closet at work
Raze
Raze Dork
7/7/11 10:51 a.m.
Yup, I've removed more rounded off bolts in exactly this manner, works the same for already rounded off 'locks'
16vCorey
16vCorey SuperDork
7/7/11 11:26 a.m.
These work well.
http://www.google.com/products/catalog?hl=en&client=firefox-a&hs=FKs&rls=org.mozilla:en-US:official&q=LOCKING+LUG+NUT+SOCKET&bav=on.2,or.r_gc.r_pw.&biw=1152&bih=734&um=1&ie=UTF-8&tbm=shop&cid=3691062932826153535&sa=X&ei=8d0VTo-II6a30AHr9dhg&ved=0CDQQ8gIwAQ
jrw1621
jrw1621 SuperDork
7/7/11 11:29 a.m.
It must be said...Shotgun!
http://www.msnbc.msn.com/id/21758302/ns/us_news-weird_news/t/they-taught-us-shop-class-use-right-tool/
Duke SuperDork
7/7/11 12:07 p.m.
Teh article wrote: The man was taken to Tacoma General Hospital with injuries Wilson described as severe but not life-threatening.
I disagree. "Stupid" is most definitely life-threatening.
Ransom
Ransom PowerDork
7/7/11 12:13 p.m.
Best line from the article is the last one:
It was not immediately clear whether the shotgun blast loosened the lug nut.
jimbob_racing
jimbob_racing Dork
7/7/11 1:13 p.m.
I've used those strip bolt removers sold at Sears. Work like a charm.
pinchvalve
pinchvalve SuperDork
7/7/11 1:43 p.m.
I've always wanted to try the Gator Grip Wrench. The principal seems like it would be ideal for this application.
turboHLS30
turboHLS30 Reader
7/7/11 1:47 p.m.
I had to pass on some 18's w/ Nitto NT555R's because of the locking lugs
Tyler H
Tyler H Dork
7/7/11 2:05 p.m.
12pt SAE socked (I mean, who uses those things anyway?) hammered over the locking lug. Works for me every time.
cliff95
cliff95 New Reader
7/12/11 10:12 p.m.
I seem to remember a 22mm socket will fit nicely when hammered onto a certain brand of wheel locks.
EW5VMlM4FKPFds0PTnljxJMwBeHF2u4nqpE2MTDacBAhNXI1jDkdCQyORt3aPItl
