Justjim75
Justjim75 Dork
11/16/19 6:48 p.m.
I must have jumped the wrong 2 connections to confirm timing and now it wont start.  No spark.  What did i burn up?  Replaced the ecu with a known good one already, EGI MAIN looks to be ok, it cranks so the 80 amp main fuse is ok from what i am told.  Any help?
Justjim75
Justjim75 Dork
11/16/19 7:22 p.m.
Im freaking out,  my car is stuck on the dyno.......
WonkoTheSane
WonkoTheSane SuperDork
11/16/19 8:04 p.m.
Check any other fuses you can find.
Can you confirm if you have spark?  If not, it's fuel related.  Any idea what you shorted when you were trying to get those you were trying to jumper those connections?
Justjim75
Justjim75 Dork
11/16/19 8:29 p.m.
Finally found a pinout, it was a fuse just like we all knew.......
Thanks for your help Wonko
WonkoTheSane
11/16/19 11:15 p.m.
Glad to hear you got it resolved :)
Which one blew?
Justjim75
Justjim75 Dork
11/17/19 1:21 a.m.
The "engine" fuse under the dash. I swapped ECUs, checked ALL the fuses,relays were tested, timing checked, checked all the fuses again, etc, then found a pinout in a thread where someone made the same mistake i did.  I read until i found the fix and checked again.  Bingo
KbjN1MtZG0U5CDabuS9lQ5R8uNexNEFBJZyExEil1HkDnGNjvjmLJEEk3OnIthpS
