Javelin
Javelin SuperDork
12/8/11 2:20 p.m.
Buying bushings for the whole front of the Javelin today. OE rubber or Prothane urethane?
Graphite used to be available too, but I can't seem to find it...
rotard
rotard Reader
12/8/11 2:43 p.m.
Do you care if it vibrates a lot at idle?
aussiesmg
aussiesmg SuperDork
12/8/11 2:50 p.m.
Check for binding issues using poly, but otherwise, poly rules IMHO
MG Bryan
MG Bryan Reader
12/8/11 2:54 p.m.
I've only had poly in an MGB, but I thought it was pretty worthwhile improvement. New rubber may have been just as good, but I kind of doubt it.
Javelin
Javelin SuperDork
12/8/11 3:30 p.m.
rotard wrote: Do you care if it vibrates a lot at idle?
The big cam and sidepipes will make it do that anyways, so... no?
Javelin
Javelin SuperDork
12/8/11 3:31 p.m.
aussiesmg wrote: Check for binding issues using poly, but otherwise, poly rules IMHO
Upper A-arm, lower control arm, spring-over-shock above the A-arm, and strut rods. I have rubber strut rod bushings which should be the only binders in that setup?
pres589
pres589 Dork
12/8/11 3:33 p.m.
In reply to Javelin:
This sort of thread comes up now and then, urethane being loved by a few and hated by more, right? Seems like a lot of installations of urethane turn noisy after time goes by.
93EXCivic
93EXCivic SuperDork
12/8/11 3:57 p.m.
What about Delrin?
Javelin
Javelin SuperDork
12/8/11 4:00 p.m.
93EXCivic wrote: What about Delrin?
They don't make those for an AMC.
My choices are:
  • Moog rubber
  • Prothane Urethane
93EXCivic
93EXCivic SuperDork
12/8/11 4:06 p.m.
They don't make those for an AMC. My choices are: * Moog rubber * Prothane Urethane
That is what god made lathes for.
Taiden
Taiden Dork
12/8/11 4:11 p.m.
I've just never personally found a significant advantage in poly for a street car. For a race car, just uh, weld it to the frame or something.
Javelin
Javelin SuperDork
12/8/11 4:30 p.m.
You gonna make them for me?
I'm still trying to find the graphite ones that used to be made...
Javelin
Javelin SuperDork
12/8/11 6:10 p.m.
To bring some closure...
Rubber.
Apparently the 70+ AMC design doesn't work well with urethane, which is why 2 makers of it stopped already.
8mUChWPfjtWOFtu9a25gvrSrJzEDcSf4giq20h2Zj00eNVxnTawz5urM3fXD3cMC
