Tom Suddard
Tom Suddard Publisher
4/21/25 2:59 p.m.
I know this isn't exactly GRM, but it's too weird not to share.
Backstory: My 14th generation Ford F-150 has a huge center console. Like, it literally has filing cabinet rails for hanging folders huge. And ever since I bought the truck, I've been vaguely aware that Dometic (the RV fridge people) makes a drop-in compressor fridge that sits in the console. It was always a novelty in the back of my mind--sure, it would be great to have cold drinks on all the roadtrips and track days I drive this thing to, but no way I'm spending $5-$600 when a cooler works fine. Still, it's pretty cool you can get an actual compressor fridge from a real brand for your center console.
Then, well, they went on sale: $100 for the 13th generation truck fridge, or $299 for the one that fits new F-150s like mine. At that price, I couldn't resist. (They've since raised the price to $149/$299). Amazon link.
It finally showed up on Friday, and I practically ran to the shop to put it in. Installation took about an hour, and most of that was me being uber careful because I didn't want to mess up the most expensive vehicle I've ever owned. I had to drill two holes deep in the console, one for a vent fan and one for power, and pop a few interior panels out of the way. It's easily reversible with some plastic hole plugs that are included if I ever remove the fridge, so I'm not too worried about the drilling. I don't really have time for a full write-up and I had my hands full working instead of shooting, but here are a few photos to give you an idea:
The fridge draws power from the OEM 12v socket in the back seat--you just unplug the wire on the back of the cigarette lighter and plug it into the factory-style plug on the fridge's harness. This means you lose the 12v port's functionality (they're worried you'll overload the circuit), but if I ever need it I can build a little splitter or just cut the wires and splice them together. I've never used it, so I left it unpowered.
Once you've drilled a few holes and plugged your wiring in, the fridge clamps to that aforementioned filing cabinet rail, gets a finish panel, and looks like this:
And, after using it for a few days--I've got to admit it's awesome. It's not huge, but it's plenty of room for a track day or a roadtrip. It's nearly silent when running, and it cools down fast. Ice forms on the interior almost instantly, so it's basically "cold bottle of water by the time you drive 10 minutes to the gym" fast.
To turn it on, hit the power button, and it'll run until battery voltage drops below 12.0 volts and shut off. In my truck's case, it cuts power to the 12v ports after a few minutes of sitting turned off, anyway. The fridge remembers its last power state so it will return to on or off when power returns. If I had a gas F-150, I might hotwire the power to run all the time. With the electric truck, though, I normally leave it "running" 24/7 when I'm at the track, anyway, so I won't bother.
Bottom line: Is this necessary? Absolutely not. But at least in my case, with 1000-mile roadtrips 5-6 times per year, track days a few times per month and mountain bike trips mixed inbetween, it's an amazing upgrade from the cooler I'm always too lazy to pack because "we're just going to the FIRM for a few hours how hot can it be."
I'm not sure how much longer the 13th generation F-150 fridges will on sale, but they look to be more or less the same thing and all these need is a 12v connection. If I still had my old camping van, I'd pick one of them up, pair it with a junkyard F-150 console, and have a compressor fridge for way less than any of the overlanding options.
JG Pasterjak
JG Pasterjak Tech Editor & Production Manager
4/21/25 3:02 p.m.
Dash-mounted toaster-oven when?
Tom Suddard
4/21/25 3:05 p.m.
Did you order one of these for your Tundra yet? They basically copied the F-150, so how different could your console be?
Toyman!
Toyman! MegaDork
4/21/25 3:09 p.m.
I like that.
Now, both of my guys who drive F150s want them.
z31maniac
z31maniac MegaDork
4/21/25 3:37 p.m.
That's pretty awesome.
californiamilleghia
californiamilleghia PowerDork
4/21/25 3:57 p.m.
any idea how many Amps it pulls  starting from  room temp until cold ?
And any reason it would not hook up to other cars / vans if you have the space ?
Thanks for the info
Tom Suddard
4/21/25 4:01 p.m.
They claim about 6 amps at startup/4.6 amps running, so it doesn't draw much power.
Wiring is easy--cut the Ford connector off, and it just needs a 12V positive and negative.
buzzboy
buzzboy UltraDork
4/21/25 4:06 p.m.
That console is huge!
I bought a DC fridge last fall for moving with food. It was so nice to travel and camp with it, and then we used it as a small chest freezer in our home over the winter. I like the idea of it being built in so it doesn't take up so much space. I don't care about drinks, but being able to pack food for roadtrips is clutch.
theruleslawyer
theruleslawyer HalfDork
4/21/25 4:22 p.m.
I can imagine it would be especially wonderful if you're at a hot job site and can jump in and have an ice cold beer before you drive. Seriously though, it looks cool. I wish my center console was cooled. They made peltier coolers for the cupholders as an option, but those things always suck. You need a compressor to make it worth the effort.
pinchvalve (Forum Supporter)
4/21/25 4:37 p.m.
Very cool (pardon the pun), that looks like an actual, real fridge. I have a small thing that cools or heats a 6 pack that plugs into a 12v outlet. I used it for some road trips, but nowadays the kids need to stop so it's been in the garage forever.
Motojunky
Motojunky HalfDork
4/21/25 4:46 p.m.
Very cool! I don't have an F-150, but I do have a small Dometic fridge in my E-350. We were just talking about fridges at our RX event this past weekend. A fridge is a game changer for camping weekends. You don't need a lot of space - you can rotate drinks in (take one, replace one) and keep a few things cool.
Chris Tropea
Chris Tropea Associate Editor
4/21/25 4:50 p.m.
I checked it out today when I was up at Toms shop to do some project car shoots and can confirm it is a very cool upgrade.
APEowner
APEowner UberDork
4/21/25 5:04 p.m.
I'd like one just to keep my phone from overheating in the parking lot on hot days.
dculberson
dculberson MegaDork
4/21/25 5:59 p.m.
I notice they also sell one for the GM line of trucks and that one is on sale for $100 on Amazon right now.
https://a.co/d/7bBmetJ
Robbie (Forum Supporter)
4/21/25 7:47 p.m.
This is a cool idea (hardeeeharrhar), but is anyone else suspicious that they aren't on sale on the Dometic website (asking $399 for all versions) yet somehow on Amazon they're for sale for $100 and $150?
my FIL would absolutely love one of these in his expedition, so I went looking to see if they had one for that.
Tom Suddard
4/21/25 11:26 p.m.
At least when I ordered, they were also on sale on Dometic's website for the same price, but without the generous return policy. Maybe it's ending soon and Amazon is just lagging behind?
I don't own a GM vehicle that this fits but bought one anyways because its $100 for a small 12v fridge. I'm going to try and fit it in a cooler or storage box.
aircooled
aircooled MegaDork
4/22/25 12:40 a.m.
I've long wondered why most (at least somewhat fancier) cars do not route AC air (and heater air) to the center console cup holders.  Not a fridge, but it would certainly keep drinks colder (warmer) longer.
brandonsmash
brandonsmash HalfDork
4/22/25 1:05 a.m.
In reply to aircooled :
Lexus has exactly that. Well, cool air anyway. They call it "Cool box."
bbbbRASS
bbbbRASS Reader
4/22/25 5:54 a.m.
My 2006 E90 had this. Heat coffe in the winter, cool "soda" n the summer.
Spearfishin
Spearfishin HalfDork
4/22/25 6:49 a.m.
Same. Figure at that price, I'll try to make it work for my uses, and if it doesn't, I'll sell it.
ScottyB
ScottyB HalfDork
4/22/25 8:02 a.m.
what a time to be alive.  that's incredibly cool and i'm jealous.
dculberson
dculberson MegaDork
4/22/25 9:01 a.m.
I think we are just going to keep passing deals back and forth and spending each other's money. (I bought the Kobalt tools on your mention of the sale, and I think you're the one I heard about the Hyundai/Kia rearview mirrors from?)
cobra17
cobra17 New Reader
4/22/25 9:17 a.m.
I read the title and instantly had an image of Xzibit in my mind.
"Yo dawg, I heard you like fridges..." laugh
Too bad my plebian-spec 2018 doesn't have the cool center console for one of those, I'd snag one up.
Enchanter
Enchanter Reader
4/22/25 10:45 a.m.
Wait...whut? What's Hyundai/Kia rearview mirrors thing?
VjtBp2gLzEMYUpv3sCiCLbrPsw8EUbcVLiIbYM8vPToMskn0IrftBs9Jwf56Y6S0
