Danny Shields
Danny Shields Reader
12/15/16 1:42 p.m.
I am about to try to revive a relative's car that has been sitting for four years or more. I presume there will be some stale gas to remove and replace with nice fresh gas. So, what does one do with the nasty old gas?
And, yes, I have seen those videos of a beer-chugging shirtless guy pouring gas on a brush pile and finding himself in the middle of a fireball. Not going there.
Rusted_Busted_Spit
Rusted_Busted_Spit UberDork
12/15/16 1:45 p.m.
Put it in a container and use for cleaning parts.
captdownshift
captdownshift PowerDork
12/15/16 1:46 p.m.
In reply to Rusted_Busted_Spit:
This, I was going to say rust remover.
gearheadmb
gearheadmb Dork
12/15/16 1:47 p.m.
It is an excellent weed killer.
EastCoastMojo
EastCoastMojo Mod Squad
12/15/16 1:54 p.m.
Make a big ass fire from some distance away?
SilverFleet
SilverFleet UberDork
12/15/16 1:57 p.m.
I usually put old gas in a gas can and keep it around for starting fires in my fire pit.
stafford1500
stafford1500 Reader
12/15/16 2:01 p.m.
you could mix it in to nearly full running cars to burn it up the way it was intended. Might take a little longer, depending on how much you have to store, but it gets rid of it in a fairly useful manner.
Fueled by Caffeine
Fueled by Caffeine MegaDork
12/15/16 2:03 p.m.
lawn mower
ProDarwin
ProDarwin PowerDork
12/15/16 2:05 p.m.
stafford1500 wrote: you could mix it in to nearly full running cars to burn it up the way it was intended. Might take a little longer, depending on how much you have to store, but it gets rid of it in a fairly useful manner.
This. Dilute it with normal gas, burn it in your lawnmower.
mtn
mtn MegaDork
12/15/16 2:07 p.m.
What kind of car, and how full is the tank? 4 years really isn't that long. I'd be inclined to just put more fuel in and then start it up.
Otherwise lawnmower/weedeater/snowblower or just mix it in a couple gallons at a time in your car.
EDIT: For reference, I've actually done this with a Buick Park Avenue with the 3800. Car had been sitting for about 3 years, and based on the tank (1/2 a tank) I would assume that the gas was at least 2 months old at the time the car started sitting.
I put in 2 gallons of new gasoline, put a new battery in it, and it started right up. Drove it to the gas station and filled it more, then to get the oil changed for $20. I ran it pretty close to dry, and filled it up again and used some of the Lucas tune-up in a bottle. It ran slightly better after that, although it was running well enough before that I'm not sure it wasn't placebo affect.
Now, I don't know that I would try this with a SAAB or Mercedes, but for most vehicles that I think of when I hear "relatives car has been sitting for 4 years" I'd assume it would be safe enough to try.
NEALSMO
NEALSMO UltraDork
12/15/16 2:32 p.m.
+1 for weed killer or dilute with good gas
I've found a SBC will burn just about anything it is fed.
Tom_Spangler
Tom_Spangler UberDork
12/15/16 2:35 p.m.
SilverFleet wrote: I usually put old gas in a gas can and keep it around for starting fires in my fire pit.
Same here, though I usually mix some used motor oil in so it doesn't go "boom" quite so quickly.
Ian F
Ian F MegaDork
12/15/16 2:36 p.m.
I agree it depends on the car. IME, modern EFI systems are amazingly tolerant of crap gas. If anything, I'd toss in a bottle or two of FI Cleaner, top it off with new gas and drive it.
Danny Shields
12/15/16 4:12 p.m.
Thanks for the suggestions, everyone. Sounds like blending should work well.
java230
java230 Dork
12/15/16 4:15 p.m.
Fueled by Caffeine wrote: lawn mower
NO!!!
Single piston small engines hate old gas more than a car will
AngryCorvair
AngryCorvair UltimaDork
12/15/16 4:36 p.m.
When I bought my first 944 it had 1/2-tank of 6-year-old gas. I started it and drove it to the gas station, filled up with 93. All this tank-draining for gas that's less than 10 years old is probably unnecessary effort.
irish44j
irish44j UltimaDork
12/15/16 4:47 p.m.
When I drained 12 gallons out of the 924 (which had been sitting for a couple years), I just added it 4-5 gallons at a time to 15 gallons of fresh fuel in our Sequoia. Burned it off, the v8 had no issue with it...
Toyman01
Toyman01 MegaDork
12/15/16 5:02 p.m.
+1 for burning it in the car it's in. 4 years isn't that old.
fasted58
fasted58 UltimaDork
12/15/16 5:07 p.m.
If it were race fuel, save a batch to burn/ huff over winter.
Plus one for adding castor bean oil.
BrokenYugo
BrokenYugo MegaDork
12/15/16 5:11 p.m.
If you can light a puddle of it with a match it will burn fine in a flathead mower engine.
alfadriver
alfadriver MegaDork
12/15/16 5:59 p.m.
Slowly put into car, run. Done.
jimbbski
jimbbski Dork
12/15/16 6:28 p.m.
Cars that have been sitting for a few years won't normally have many issues with the fuel in the tank. It's the possible water and/or dirt/rust that they may have problems with if any is present. Clogged fuel filters and injectors usually result. Newer cars have sealed fuel systems that keep the amount of water forming in a tank to a minimum. It also keeps the amount of fuel that can evaporate low as well. When gasoline evaporates it leaves that brown "varnish" that you see in a cars intake, etc.
That's why "old" cars which don't have sealed fuel systems can have issues from sitting. Water can form in the tank, rust appears, the fuel evaporates, and you then have a thick sludge that used to be gasoline to deal with.
GTXVette
GTXVette Reader
12/15/16 7:17 p.m.
gearheadmb wrote: It is an excellent weed killer.
It Kills Kudzu and any other weeds in the way. If you love your lawn Mower you won't use it in it. and then get Non-Ethanol gas for your mower.
Brett_Murphy
Brett_Murphy PowerDork
12/15/16 9:01 p.m.
jimbbski wrote: Cars that have been sitting for a few years won't normally have many issues with the fuel in the tank. It's the possible water and/or dirt/rust that they may have problems with if any is present. Clogged fuel filters and injectors usually result.
This. I siphon it out through a coffee filter, then add it back into gas tanks on top of new gas.
chada75
chada75 Reader
12/16/16 12:04 a.m.
In reply to java230:
Ain't that the truth.
siAgFnfD8gHoTnM9G8vsrQNPDQnmtuahG5v33rTjEd32kgedbmCtwE7gvlVkVx0S
