SKJSS (formerly Klayfish)
SKJSS (formerly Klayfish) PowerDork
2/3/22 1:57 p.m.
For some reason my phone has suddenly started cycling WiFi connection off and on.  It's on for 2 seconds then off for a few seconds, over and over.  I restarted the phone, nothing.  I made the phone "forget" the router and reconnected it, nothing.  Everything else in my house seems to be working fine.  What gives?
The phone is a Motorola, relatively new (though not a high end one).
Stampie
Stampie MegaDork
2/3/22 1:59 p.m.
In reply to SKJSS (formerly Klayfish) :
I'm going to go with sometimes things break. Have you tried it on a different wifi network just to double check?
2/3/22 2:06 p.m.
If it's just the phone and restarting doesn't fix it, the remaining options are limited. Any major OS updates recently? If an update didn't cause it, the remaining options are "factory-reset the phone" and "toss the phone." If the same thing happens on other wifi networks that again would tell us it's either a hardware problem (on your single-board SoC computer) or a driver issue (which would've been introduced by an OS update).
2/3/22 2:12 p.m.
Thanks!  I'm not sure if it's doing it on other networks as it just started happening.  I'll go out later and find a free wifi to connect to and see what happens.  The phone is only a few months old, so hopefully it's still under warranty.
californiamilleghia
californiamilleghia UltraDork
2/3/22 2:13 p.m.
you might post something on howardforums.com
Thats the big forum for phone geeks !
mq0zaZQmHQAwL3x3538qVICrzfvmzOawvD9hi6MYjUoS781NZ2PnaG5ZhobTZXFT
