Actually the SDS says te concentrate is 1-5% peroxide. You are then diluting that @ 2oz/gallon, so final peroxide concentration would be 1-5% OF that 1.56%. As a reference, over the counter "peroxide" in the brown bottle is usually 3% H2O2 in distilled water.
For everyone's reference, here's how you can find the full, EPA approved label for any EPA-registered product. First, you need the product name or, better yet, the EPA Registration Number. Every registered product has one and it is required to be listed on the label. Some companies inclue it on the SDS, but it's not a requirement.
So, from the SDS Whelsmithy linked above, the name is likely "Maxim Facility +". It's not always as easy as you'd think to decide what the official correct name is.
Next, go to THIS EPA WEBPAGE where youu can search for product by different criteria. Put the name in the "Product or Alternative Brand Name" box. This is where things get tricky. This search can be pretty nit-picky about how you spell stuff, punctuation, etc. as you start typing it will offer you suggestions based on the entries in the database. Use those to find what you're looking for. If there are no pop ups, you're likely not using the "correct" name in some way.
Hit the search button at the bottom of the page and you get this:
Notice the product name listed here is HP2O2? It's not unusual that a single registered product has many alternate brand names. At the bottom you have multiple tabs of available info. The main one is Labels, where you can see a chronological list of labels that the company registered with the EPA. Clicking these will open the PDF of what's called the "Stamped Label."
A Stamped label is a huge document that covers every possible organism claim that the company has data to back up, along with every possible use pattern, alternate name, marketing statement, or label drawing that the company might want to use. It's a large bank of stuff that a company can then pick and choose from to create different "products" or even different labels for the same product that may be focussed on different users or markets. Sometimes it takes a lot of work to sort through a full stamped label to find the info you want.
One last piece - notice the Reg No above only has one dash in it? That means it's a "primary" registration - this company developed the formula, paid for the testing, and registered the formula. If a Reg No has 2 dashes, it's a "Secondary" registration - meaning the company is paying a primary registrant to use their data and formula under a rebranded name. To find the stamped label, remove the final -## from the Reg No and search just the first part, that's the original primary registration . IE, a Reg No of 45745-11-12 would be a secondary registration of this primary, 45745-11.
Any questions? There will be a quiz at the end of the clas...
