5/16/21 12:36 a.m.
I need to find a hypotenuse and my geometry is failing  me. I have a right triangle. A and B are equidistant so my angles are 90, 45, and 45. My perpendicular bisector to the hypotenuse is 4.5. What's my hypotenuse?
jgrewe
jgrewe HalfDork
5/16/21 1:08 a.m.
9? I think I'm picturing what you are describing.
mtn
mtn MegaDork
5/16/21 1:09 a.m.
If I'm understanding this correctly, your hypotenuse is 9. In this picture, you're trying to find Y, right?
When you cut an isosceles right triangle in half from the right angle, you get another, smaller isosceles right triangle.
If you want more detail, as I skipped a step or two in this "proof"  here, happy to give it in the morning.
5/16/21 1:15 a.m.
That looks right. I found a bunch of tutorials,  but was unsure what they were labeling A B C as, the sides or the angles.
mtn
mtn MegaDork
5/16/21 1:20 a.m.
What's the application?
Scott_H
Scott_H Reader
5/16/21 1:45 a.m.
Use a Trig calculator.  Google it and there are tons.  Or, there are apps.  You really don't need it for this though.
http://www.carbidedepot.com/formulas-trigright.asp
I would make a smaller triangle (the blue one in the second image below) inside of your original triangle with 4.5 as one leg of the the new smaller triangle.  The angle is still 45 degrees so the other angle is 45 degrees which means the other leg (half of your original triangle is the same 4.5.  So, the hypotenuse is 9.0 of the original larger triangle.
9.0 is what I get.
5/16/21 4:08 a.m.
4" pvc pipe through the floor. OD is 4.5" Want to figure what size wall is needed box it in.
akamcfly
akamcfly Dork
5/16/21 5:30 a.m.
Sin 45deg is 1.414 so your hypotenuse should be 1.414x the length of one of the other sides
5/16/21 6:59 a.m.
In that case won't your hypotenuse be 4.5" + 0.5"(or whatever the thickness is of the material you're boxing it in with)?
jgrewe
jgrewe HalfDork
5/16/21 10:56 a.m.
The pipe isn't going to reach all the way into to 90* angled corner so your dimension isn't 4.5".  More math needed or just throw the pipe into a corner and see how far it sticks out.
5/16/21 3:17 p.m.
Your proof is flawed. In your pic, x^2 + x^2 = 81, not 9.
Tom_Spangler (Forum Supporter) PowerDork
5/16/21 3:47 p.m.
SVreX (Forum Supporter)
SVreX (Forum Supporter) MegaDork
5/16/21 5:04 p.m.
I'm missing why so much math.
Cut a bigger hole, make it as tight as you can, patch back.
It's not more work to make a slightly bigger hole.
5/16/21 7:56 p.m.
In reply to SVreX (Forum Supporter) :
I want to make sure the drywall and lumber I have is big enough to enclose the pipe that goes from the basement to the roof. I really don't  want to buy a $700 2x4 if I don't have to.
5/16/21 8:07 p.m.
In reply to Appleseed :
OK, but I think you are asking the wrong question...
If the perpendicular of your triangle is 4.5" and 4.5"is  the outside diameter of your pipe, it won't fit in the triangle.  You need a triangle whose legs can encompass a 4.5" diameter circle.  That's not the perpendicular line.
And why are you making the pipe chase triangular?  Isn't it easier to square it off?
It's so much easier to lay this out as a practical "without" the math.
5/16/21 8:18 p.m.
One more problem...
PVC pipe is 4.5".  But the hubs and fittings are not.  The hub of a 4" pipe is 5", not 4.5".  If you have any joints or fittings at all in this chase, your pipe won't fit.
I know you are trying to save precious 2x4, but you are not giving yourself any tolerances.
5/16/21 8:21 p.m.
You can build a very adequate pipe chase with NO 2x4's.  2 faces of drywall with a 1x1 cleat on the backside in the corner is sufficient.  It can also be done with no wood at all- just a sheet metal angle on the back corner of the drywall and metal drywall screws.
I can name 20 ways to build a pipe chase that don't include any math! Haha!
ProDarwin
ProDarwin MegaDork
5/16/21 8:32 p.m.
this.
(just showing the problem, I agree with svrex here)
5/16/21 8:37 p.m.
You guys really need to go back and get a refresher in your geometry...
fasted58
fasted58 MegaDork
5/16/21 8:50 p.m.
Make trial templates from pizza or beer boxes.
5/16/21 8:57 p.m.
E36 M3, coupler OD size.  This is why I ask things like this. That's an important thing I overlooked.  I'm just going to use Ed's pizza box idea.
5/16/21 9:10 p.m.
YES!
Ed and his pizza boxes for the win!
5/16/21 9:14 p.m.
One more thing...
Trust me on this.  If you try to save pennies of wood by calculating this chase so closely with ZERO tolerances, you WILL be building it twice.  I'm not trying to be an ass, I'm just trying to help you benefit from my 44 years of construction experience.  It NEVER goes together as easily as the engineers can draw it.  You HAVE to include tolerances.
Do yourself a favor... Make it a little bigger so you don't have to worry about it later.
mtn
mtn MegaDork
5/16/21 9:22 p.m.
That's what I get for trying to do math at 1:30am.
5/16/21 10:55 p.m.
One more thing...
Oh, trust me, I've paid the price forgetting the saw takes an 8th every cut.
LRkw9Scp6Fggqt8TLgG81QpUmj3ciBy0yOyWLOwX9OYerRB5lndy6ETNbvq2Mx5J
