Mental
Mental SuperDork
12/21/08 9:49 p.m.
Using a medieval ballistics device, how would you do it?
2 years ago I built this trebuchet For the Manitou Springs Fruitcake Toss
It was disassembled and forgotten. Now it sits on my garage floor awaiting a rebuild. While examining the bits I had 2 thoughts. 1. Its cold, I am going back inside. 2 Ya know, the GRM board has several engineers, including a ballistics specialist, and a lovely collection of miscreants. I bet they could help.
The arm is 9 ft 5 1/2 inches. The pivot is 2 ft 8 inches from the basket. The basket is large enough for anything, but the fruitcake will weigh less than a pound. I am bound by these Rules I have about two weeks, almost no budget and good access to scrap lumber.
What have ya got? Thanks for your time.
rebelgtp
rebelgtp HalfDork
12/21/08 9:57 p.m.
I bet I'm not the only one thinking sabot and pneumatic canon
http://www.youtube.com/watch?v=yHfejwdrMVQ
Luke
Luke Dork
12/21/08 10:40 p.m.
How effective was your trebuchet?
A Catapult would be mighty cool, if you could knock one up in two weeks. Also, according to those rules, the cake has to weigh either 2 or 4 pounds.
Mental
Mental SuperDork
12/21/08 10:57 p.m.
Yeah, the weight rules are lightly enforced. But lets say 2 lbs
We got a single non-measured distance of about 300 ft, but the money shot had us at about 90 ft.
bluej
bluej HalfDork
12/22/08 6:57 a.m.
from a similar trebuchet building contest in high school, i remember the hardest part was consistency in the departure angle. the rest is all just simple mechanics (increase weight, move fulcrum closer to weight, etc.) seems your results would indicate a similar inconsistency.
we did manage to smash a glass marble against the concrete wall the opposite length of the gym with just a soda can for weight. that was fun
i am jealous of the awesomeness of your town.
Tommy Suddard
Tommy Suddard
12/22/08 7:55 a.m.
The 4th Challenge Event?
John Brown
John Brown SuperDork
12/22/08 8:09 a.m.
I had visions of a bunch of Chair Force guys using a mobile home as a drop ballast against a pivot board...
walterj
walterj HalfDork
12/22/08 8:40 a.m.
How do you get the fruitcakes to stop squirming and yelling for help long enough to load them onto the Trebuchet?
Tommy Suddard
Tommy Suddard
12/22/08 8:45 a.m.
Duct Tape.
John Brown
12/22/08 9:08 a.m.
Rum, if you read the other threads...
Snowdoggie
Snowdoggie Reader
12/22/08 9:14 a.m.
I keep thinking of that infamous Monty Python catapult scene.
Pichez la Vache!! Pichez la Vache!!
aircooled
aircooled Dork
12/22/08 10:29 a.m.
I believe if you have the pivot point able to slide fore and aft it will increase the efficiency (fore and aft forces are transmitted to the projectile rather than the ground).
Salanis
Salanis SuperDork
12/22/08 10:59 a.m.
aircooled wrote: I believe if you have the pivot point able to slide fore and aft it will increase the efficiency (fore and aft forces are transmitted to the projectile rather than the ground).
In general, the more you can make the weight move strait down, the more efficient your trebuchet will be.
Putting the weight on a pivot makes a big difference. Putting the weight farther down from the pivot helps a lot too (more than you'd expect).
Setting up a trebuchet like what aircooled said is incredible efficient. Make the weight fall straight down in a channel, and have the fulcrum slide along a level platform.
aussiesmg
aussiesmg HalfDork
12/22/08 11:38 a.m.
Snowdoggie wrote: I keep thinking of that infamous Monty Python catapult scene. Pichez la Vache!! Pichez la Vache!!
Run away, run away
bluej
bluej HalfDork
12/22/08 10:46 p.m.
In general, the more you can make the weight move strait down, the more efficient your trebuchet will be. Putting the weight on a pivot makes a big difference. Putting the weight farther down from the pivot helps a lot too (more than you'd expect). Setting up a trebuchet like what aircooled said is incredible efficient. Make the weight fall straight down in a channel, and have the fulcrum slide along a level platform.
hmm..... large weight falls straight down channel, pulley system to convert to a high speed launching ramp at the ideal angle. this addresses the biggest variable we had which was the release angle of the trebuchet "sling" like i said above.
SVreX
SVreX SuperDork
12/23/08 10:46 a.m.
Dog, that's awesome! I wish I lived in CO!!
OK, so there's a distance limitation. 260' sounds pretty attainable.
But I note (with eagerness) that there is apparantly no height limitation!
I'm thinking you need to shoot for the moon with a landing within 260'.
bluej
bluej HalfDork
12/25/08 9:15 a.m.
SVreX wrote: Dog, that's awesome! I wish I lived in CO!! OK, so there's a distance limitation. 260' sounds pretty attainable. But I note (with eagerness) that there is apparantly no height limitation! I'm thinking you need to shoot for the moon with a landing within 260'.
ooooOOOOOOoooooo! big splat!
JeepinMatt
JeepinMatt New Reader
12/27/08 2:51 a.m.
C'mon, let's get real here
taY2pJHXvh0dPY5SezgYp5OeyTstyGr3lXyq83FdmryGHxkmvlfMfvXDhlLQo7vf
