drsmooth
drsmooth HalfDork
6/4/18 1:39 p.m.
I have a manual transmission NB Miata.
If  gearbox oil is low, will it give the P705 code. Or is it only for a faulty Neutral position switch?
The automatic NB, from what I have read gives the code for a faulty senor or for low oil.
6/4/18 1:57 p.m.
You mean P0705, right? I'm basing this on a 2001 workshop manual.
DTC P0705
Transmission range (TR) switch circuit malfunction (short circuit)
DETECTION CONDITION
  • Any of P, R, N, D, 2, or 1 positions/ranges switches are ON for 10 seconds or more.
  • Diagnostic support note:
  • This is a continuous monitor (CCM).
  • MIL illuminates if TCM detects the above malfunction conditions during first drive cycle.
  • PENDING CODE is not available.
  • FREEZE FRAME DATA is available.
  • O/D OFF indicator light does not flash.
  • DTC is stored in TCM memory.
POSSIBLE CAUSE
  • TR switch malfunction
  • Short to power between TR switch terminal B and X-09 connector male terminal Q
  • Short to power between TR switch terminal J and X-09 connector male terminal Q
  • Short to power between TR switch terminal F and X-09 connector male terminal C
  • Short to power between TR switch terminal H and X-09 connector male terminal R
  • Short to power between TR switch terminal E and X-09 connector male terminal N
  • Short to power between TR switch terminal G and X-09 connector male terminal I
  • Short to power between X-09 connector female terminal Q and TCM terminal F
  • Short to power between X-09 connector female terminal C and TCM terminal D
  • Short to power between X-09 connector female terminal R and TCM terminal C
  • Short to power between X-09 connector female terminal N and TCM terminal B
  • Short to power between X-09 connector female terminal I and TCM terminal A
  • Damaged connector between TR switch and TCM
  • TCM malfunction
drsmooth
drsmooth HalfDork
6/4/18 2:12 p.m.
In reply to Keith Tanner :
WOW! that was a fast reply, and yes you are correct P0705
drsmooth
drsmooth HalfDork
6/4/18 2:18 p.m.
I am at work and had to type my first post quickly. Just wanted to clarify my horribly worded first post. It is a manual transmission that gave the P0705 code. I will update my post above to reflect that.
6/4/18 2:22 p.m.
For manual transmission:
DTC P0705
Neutral switch input circuit malfunction
DETECTION CONDITION
  • The PCM monitors changes in input voltage from the neutral switch. If PCM does not detected the PCM terminal 4H voltage does not change while vehicle speed above 30 km/h {18.6 mph} and clutch pedal depressed above 14 times, it determines that neutral switch circuit has malfunction.
  • MIL illuminates if PCM detects the above malfunction condition in two consecutive drive cycles.
  • PENDING CODE is available if PCM detects the above malfunction condition during first drive cycle.
  • DTC is stored in PCM memory.
POSSIBLE CAUSE
  • Neutral switch malfunction
  • Open harness between neutral switch terminal A and PCM connector 4H
  • Short to power between neutral switch terminal A and PCM connector 4H
  • Short to GND between neutral switch terminal A and PCM terminal 4H
  • Open harness between neutral switch terminal B and GND
  • Short to power between neutral switch terminal B and GND
  • PCM malfunction
drsmooth
drsmooth HalfDork
6/4/18 2:24 p.m.
You have my sincerest gratitude!
mArW3TpR4hT3C51tMZEyAqoB2g5U9xawVAHc4Kf6VEyKiGtJf2w3U9itrvVvH3SP
