BrockwayEngineering
BrockwayEngineering None
6/1/11 8:05 p.m.
The DGauge is a digital multi-gauge that plugs into the diagnostic port on most 1996 and later Asian, European and some US vehicles and displays real-time engine data on it's color TFT LCD. Through the selection of one of 3 different screen modes, you can monitor 2 or 4 user selectable parameters at a time. As many as 25 different parameters are available for viewing, depending on vehicle support and 7 parameters via external sensors. Optimized for track use, the DGauge includes a shift light output, gear position indicator and excellent visibility in all lighting conditions, including direct sunlight. Exceptionally easy to set up and operate. With unmatched performance and reliability, the DGauge offers the most advanced technology in engine monitoring.
Supported OBD parameters:
STF (Short Term Fuel Trim) %
LTF (Long Term Fuel Trim) %
CLV (Calculated Load Value) %
ALV (Absolute Load Value) %
RPM (Engine RPM)
IGN (Ignition Timing) °
TPS (Throttle Position Sensor) %
MAP (Manifold Absolute Pressure) kPa
BP (Boost Pressure) kPa or psi
MAF (Mass Air Flow) g/s
ECT (Engine Coolant Temperature) °F or °C
EOT (Engine Oil Temperature) °F or °C
IAT (Intake Air Temperature) °F or °C
AAT (Ambient Air Temperature) °F or °C
O2 (Oxygen Sensor Voltage) v (Bank1 and Bank2)
AFR (A/F Ratio) (Bank1 and Bank2)
ALC (Fuel Alcohol Level) %
VSS (Vehicle Speed Sensor) mph or km/h
BAT (Battery Voltage) v
FRP (Fuel Rail Pressure) kPa or psi
GR (Gear Position) 1,2,3,4,5,6
Some parameters not available on all vehicles.
Supported external sensor parameters:
AFR (A/F Ratio)
EGT (Exhaust Gas Temperature) °F or °C
OIL (Oil Pressure) kPa or psi
Features:
• 3 screen modes that allow the user to select the data displayed.
• Selectable color for each "Gauge".
• Speed and Temperature can be displayed in Metric or English units.
• Pressure can be displayed in kPa or psi.
• Reads and clears diagnostic trouble codes (DTC's).
• Turns off check engine light (CEL).
• Displays boost on vehicles equipped with a MAP sensor.
• Displays A/F ratio on vehicles equipped with an OEM wideband O2 sensor.
• 2 external sensor inputs.
• Programmable shift light output.
• Adjustable alerts for ECT, EOT, EGT, BP and OIL.
• Adjustable LCD brightness.
• Fast update rate.
• Data output for logging.
• Updatable Firmware.
• Simple Plug and Play installation with included Data Link cable.
• Advanced high reliability 3" TFT LCD. Readable in direct sunlight.
• Automotive grade components used throughout.
• Compact size (5.2"x 2.2"x0.75"). Includes mounting brackets.
• A/F ratio conversion for Honda/Acura K20 engines built from 2002 to 2004.
Options:
Shift Light - The shift light output is adjustable from 3,000 rpm to 9,900 rpm in 100 rpm increments. The output can drive an LED shift light such as the SL2A (sold separately).
External Sensors - The DGauge has 2 external sensor inputs. Sensors and sensor connection cables are sold separately.
Micro Mount - The Micro Mount is an elegant non-permanent mounting solution.
See our website for complete details and demo video: http://www.brockwayengineering.com/dgauge.html
BrockwayEngineering
BrockwayEngineering New Reader
7/20/11 12:50 a.m.
New firmware just released! We added LTF and ALV for vehicles that support it. Also, for vehicles with a MAP sensor, we added a new parameter for BP (Boost Pressure) and an auto calibration feature.
BrockwayEngineering
8/25/11 12:44 p.m.
Gear Position indicator added to the DGauge. Here is a video showing the performance: http://www.youtube.com/watch?v=ifNCPkbQHh0
It's a bit blurry due to the engine/vehicle vibrations. Best we could do with the camera mount that we have.
BrockwayEngineering
10/19/11 1:03 p.m.
See the DGauge in action on the track: http://www.youtube.com/watch?v=kIS-pdPovC0
OcIjT0IBfGI1xj88rmqNzUe1CJ8iA6IBZ9nW64vExy0fWATWaGoWj4mhEuJFqURP
