eastsideTim
eastsideTim PowerDork
5/4/21 11:38 a.m.
This is probably obvious to a lot of people, but I can't believe I held out this long.  I'm in the Midwest, and have an uninsulated attached garage, with not so great doors, and have been having humidity problems with it for years.  Been using the desiccant-in-a-bucket, and running a fan to circulate air occasionally to try to keep it under control, with only marginal results.
Bought a dehumidifier last night and set it up this morning.  Went from 66% relative humidity in the garage to 54% in just 3 hours.  There was nearly a gallon of water in the drain pan when I emptied it at lunch.  The garage is noticeably more comfortable, too.
5/4/21 11:51 a.m.
Florida has serious humidity, especially in the summer. I've had one, and sometimes two of them in my detached garage.
 I'm going to insulate the walls and door and add a window AC this year.
Toyman01 + Sized and
Toyman01 + Sized and MegaDork
5/4/21 11:55 a.m.
Summertime, I frequently leave the AC running at about 80 degrees and just suck up the extra on the electric bill. It keeps the lathes, mill, and bandsaw from rusting.
5/4/21 12:00 p.m.
I've got the window unit installed in the wall already, but I've got to shift and tilt it so it drains off the back. I tried running it last year and a lot of the condensation ran down the inside of the wall.
eastsideTim
5/4/21 12:03 p.m.
In the past, I have considered getting a window AC unit and cutting a hole in the wall for it.  It'd be nice to have a somewhat cooler garage along with the reduced humidity, but I feel like  I should pull the drywall and insulate the garage if I'm going to do that.  I suspect the lower humidity with the dehumidifier will also make the garage more comfortable at higher temps, so I won't need the doors open for extra air circulation as often.
5/4/21 12:36 p.m.
You might look into a mini-split. Some of them are fairly economical and can also provide heat. I have a 2-ton heat pump unit in my shop. It makes me much more likely to work out there during weather extremes.
88Rr6VEPjkvmi8dMa0elM3DZQO2KaFkfL3cpPTbaEI37692EylbcKdbCDaVJSvzf
