Started on April 15 by otownFLA
2006 Mitsubishi Evo IX
Hi my name is Matt Dennison and I’m from Southern California. I drive an 2006 Mitsubishi Evolution IX and I’m currently competing in the Redline Time Attack series and a 2009 RTA Class Champion Engine/Drivetrain Modifications: -ROAD RACE ENGINEERING dyno tune -ROAD RACE ENGINEERING GT3076r turbo kit -MISHIMOTO radiator -MISHIMOTO air diversion plate -MISHIMOTO silicone radiator hoses -AMSOIL fluids -MIL.SPEC 100 cell catalyic conveter -Cosworth 280in/273ex M3 camshafts -ETS 3inch front mount intercooler -ETS 2.5inch lower IC pipe -Dejon dual stage MBC -AEM short-ram intake -Megan 3inch TBE -Walbro 255lph fuel pump -Precision Turbo Engine 780cc fuel injectors -ACT heavy duty clutch w/ Streetlite flywheel -ARP head studs -Road Race Engineering front motor mount -42 draftdesigns water temp housing -SUN Auto Hyper Grounding kit -SUN Auto Hyper Voltage type MR Suspension Modifications: -ROBISPEC aligned and corner balanced ~~front~~ -ROBISPEC KW Clubsport 2-way adj. coilovers -Whiteline roll center kit -K-Mac camber/caster plates ~~rear~~ -ROBISPEC KW Clubsport 2-way adj. coilovers -ROBISPEC 26mm 4-way adj. swaybar -ROBISPEC swaybar endlinks -Whiteline rear bump steer bushings -Whiteline trailing arm bushings -Cusco pillowball top mounts Wheels/Tires Modifications: ~~front~~ -Konig 18x9 +30 runaways -FEDERAL tires (street) -Rays Gram Light 57 maximum 17x9 +22 -FEDERAL 595RS-R 255/40/17 (track) -Brembo 4-pot calipers -EBC slotted/dimpled rotors -Raybestos ST43 pads -Road Race Engineering stainless brake lines -MOTUL RBF600 brake fluid ~~rear~~ -Konig 18x9 +30 runaways -FEDERAL tires (street) -Rays Gram Light 57 maximum 17x9 +22 -FEDERAL 595RS-R 255/40/17 (track) -Brembo 2-pot calipers -Brembo rotors -Raybestos ST43 brake pads -Road Race Engineering stainless brake lines -MOTUL RBF600 brake fluid Interior/Exterior Modifications: ~~interior~~ -PROSPORT 60mm Premium boost gauge -PROSPORT 60mm Premium oil temp gauge -PROSPORT 60mm Premium water temp gauge -PROSPORT 60mm Premium oil pressure gauge -PROSPORT oil filter adaptor plate -Gruppe-S gauge panel -HKS turbo timer -OEM radio relocation kit -Schroth Rallye 4 harness ~~exterior~~ -APR GTC-200 spoiler -APR front air dam -APR rear diffuser
Add your comment
See more
rDwW6e0jya9zJu6VVujbD49w0fLNwc2EvVfhLEI3QtAhFUV9hHRYm077n2hItbXw
