Started on March 20 by supergoji
1991 Nissan 300zx 2+2 twin turbo
Intake: Dual 370z shorty filters Ashspec 2.5” intake piping Ashspec turbo 3” Inlet pipes Ashspec V3 Intercoolers Electronics: Haltech elite 2500 Fuel: Brett dempsey engineering topfeed ID1700cc Fuelab 1800hp pump 92902 Fuelab regulator 52902 Drivetrain: Twin turbo Steering rack with energy suspension bushings Motul RBF 600 fluid (clutch) Z1 1 piece Stainless steel clutch line JWT 525lb-ft JWT lightweight flywheel Z33 6spd JWT swap kit Z32 trans Zpeed SOLID shift mount kit Zspeed heavy duty cast iron clutch fork and chromoly pivot ball Z1 Premium short shifter New throwout bearing ENEOS fluid in the trans and diff BDE Low profile semi solid motor mounts SPL parts Subframe and Differential Solid Mounts Z1 1 Piece driveshaft Full Z1 Hicas delete - Non turbo power steering pump and mount Turbos: GTX2967 stock 5spd Turbos with machined inlet for faster spoolup and less intake turbulence Exhaust: Random technology 3” bellmouth downpipes Z1 3”-2.5” test pipes B&B 2.5” suspension: Powertrix SS coilovers SPL Z1 Fucas New outer tie rods SPL parts V3 tension rods Brakes: R35 GTR brake kit 6 piston front 4 piston rear oem drilled rotors stainless lines all around Brake master cylinder brace exterior/interior: OEM black suede interior OEM black leather seats 30%tints DDM tuning HIDS, 55 watt 3000k fog lights, 55 watt 4500k low beams, 55 watt 5000k high beams 99 OEM front fascia 99 OEM tail lights 99 OEM rear spoiler TwinZ Widebody ZThirtytwo Carbon kevlar cowls Winfactory hood struts Navan shift knob Blitz 03 18x10 +5 / 18x12 -5 Gewalt evo II 19x9 19x10 Pilot super sport tires 265/30/19 front 295/30/19 rear Future Projects midnight purple III (TBD) 350z 6 speed transmission swap (in progress) 2.937 R230 armada rear end swap (in progress) S2k projector retrofit aftermarket seats CCW or HRE wheels R35 Brake swap (in progress) Fuel setup (in progress)
Add your comment
See more
utZQWD6MTGUyAlKn1tsJtntgnqjfWGE8coB0m1tQdqTJ1sMNtbdhGzuBAKhNvJxY
