Started on April 29 by caanglin
1997 Volvo 850R
Engine: ARD Green tune OBX turbo back NA manifold NA throttle body Silicone inter-cooler hoses Samco coolant hoses NGK plugs Suspension: IPD blue springs Koni Yellows XC90 Spring seats Meyle HD end-links ipd sway bars EuroSport Tuning carbon-fiber strut bar Brakes: 302mm Drilled/Slotted rotors Stainless steel lines Akebono Euro Ceramics (meh) Interior: T5-R shift knob X70 gauge cluster Prosport boost gauge Exterior: ipd old style grille Clear corners V70 tail lights V70 side markers 18” ASA AR9’s w/ Kumho Le Sport 35/20% tint Misc: ipd poly torque mount ipd poly transmission mount ipd poly subframe inserts Maintenance: Alignment Motor mounts Fire wall mount Strut mounts Timing belt ABS/TRACS module Meyle HD Control arms Meyle HD Tie-rods Thermostat Trans fluid Brake fluid
Add your comment
See more
5JgPM5sIhDie5MOBSJlQ8bkJdbtk5LjmTJT9I0tTvdNLnGUJmqQOOwtB2hhEGfNI
