Started on April 29 by caanglin
1986 Porsche 944 Turbo
Engine: Vitesse MAF Hallman MBC @ 15psi Weltmiester wastegate shim Test pipe Bosch 3bar FPR 83# injectors Silicone vac lines Suspension: Weltmiester 250lb springs Koni yellows Lowered rear eccentric bolts 1.5” spacer front 2” spacer rear Brakes: Zimmerman blanks Axxis Metal Master pads Stainless steel lines Ate super blue fluid Interior: Personal Grinta Prosport boost gauge Escort Passport JVC head-unit Exterior: 18x8 and 18x10 997 Turbo reps 997 Turbo front lip Red turn signals 20% tint Misc: Venturi delete Cycling valve delete PS delete Maintenance: Bosch plug wires Bosch plugs Fuel lines Coolant expansion tank Coolant hoses Thermostat DME temperature sensor Motor mounts Timing belt Heater valve Suspension bushings Axles
Add your comment
See more
K0MxrrShMIUFUXf9oOBxrvkDCeYaO4XDChByKeaOkAxR99Cx0oyRKBV0GT16R1wB
