Started on Dec. 1 by MailmAn
1975 Plymouth Fury Custom
2-Door Hardtop Body Style with Vinyl Top; Original 318cid V8 Engine; Weiand Dual-Plane Aluminum Intake Manifold; Carter AFB 625CFM Aluminum 4-Barrel Carburetor; Mopar Performance Black-Wrinkle Finish Valve Covers and Air Cleaner; Triple Row All Aluminum Racing Radiator; Hooker Full-Length Competition Headers with 3” Collectors; 2.5” True Dual Exhaust System with “Purple Hornies” Glasspack Mufflers; Original 904 3-Speed Automatic swapped for Heavy-Duty 727 3-Speed Truck Transmission; Shortened Driveshaft to fit 727 Transmission; Prothane Polyurethane Bushing Kit (Installed in 2010); Braided Stainless Steel Flexible Brake Lines (Installed in 2011); (Engine is due for a complete rebuild and car is currently off the road. Planning on replacing cam, increasing compression, bore block .030” over, new pistons and rings, and working over heads…)
Add your comment
See more
2cCvAAQefTFINw16lw7mhiDqbeApPdG9HB1JiwDjNx3cPSK5Fy9URLMR2yTOmPLB
