Started on May 26 by tommyh
1997 Saturn SC2
OK, here’s the deal. This is my 1997 Saturn SC2 that I bought in February 2000. It’s the DOHC motor with the stock 5-speed manual trasmission. No power windows, no cruise control, no power seats, no nothin’, and I like it like that. I’ve modified the hell out of this little car, though it doesn’t necessarily look like it. It runs great, drinks the cheapest, nastiest swill possible to call “gasoline”, uses very little gas at that (~40MPG highway), it’s impressively quick for the front engine front wheel drive econobox that it is, and it handles better than it should. I think it looks great, even after all these years I think the styling of the car is better than most any other “sporty” car out there. Nearly everything I’ve done to the car has been in order to make it more fun on back roads, road courses and be a car used to autocross in the DSP class. It’s probably time for me to move onto something else to use as a toy (who the hell has a Saturn as a “toy”, I know). I love this damned car. It’s just so damned chuckable. I’ve driven and owned other cars that will/can/have gotten me in trouble with the laws of both man and physics, but this damned Saturn hasn’t, and leaves me smiling like a schoolboy after a stolen kiss on the play ground. Built in 12/96 but with only 106460 miles on the car and owned by me since I bought it with 32K on the clock. This “Blackgold” car is about a shade “golder” than Subaru’s gold flecked black paint that was on the 04/05 Impreza cars. I’ve done a bunch to the car over the years and am not sure I’m remembering everything. Exterior: Hella Optilux driving lights wired into stock locations Silverstar high and low beam headlights Suspension: KYB struts H&R Sport springs (Springs and struts installed at same time with new factory top-hats) SPS 16mm rear swaybar H&R 5mm front wheel spacers SPS strut tower bar Wheels, tires & brakes: 15”x7” SSR Competition wheels Falken Azenis RT615 tires Rear drum-to-disk conversion using factory parts EBC Green pads on front wheels Goodridge braided stainless steel brake lines Interior: Corbeau A4 seats Corbeau 4 point harnesses Pioneer CD head unit Pioneer speakers in original locations Engine: Hotshot 4-2-1 header SPS cat-back exhaust Ported & polished throttle body with knife-edged butterfly valve (hand worked) K&N filter on TB reversed cowl induction intake setup w/ relocated intake temp sensor Valvoline full synthetic oil since 34,000 miles Other & weight reduction: Optima Red Top battery re-located to trunk with custom enclosure and mounting brackets with isolation switch in engine bay Air conditioning system disconnected and all parts removed Stock seatbelts removed Sound deadening removed from behind: firewall roof doors rear seat area trunk hood dashboard under carpet
Add your comment
See more
T3QxQ3kDZKxMIQ4au8zNQbcOS7Q2I3Ga6moJwoYGbyxaHhWgNwZjPIXDPCz47niG
