Started on June 19 by Egz
2003 Ford Focus ZX3
218HP/155 Ft-Lbs Supertech 12.5:1 pistons Eagle H-beam rods Ranger crankshaft ARP studs and fasteners Crower F-2372 camshafts by Massive Speed System Crane valve springs and retainers Cosworth BSD Marcy Motorsports 3-angle valve job Cosworth intake manifold Modified eBay oil catchcan Custom short ram with 3” MAF tube & heat shield Cosworth header + flex Modified Tru-Bendz 2.5” Exhaust Tuning by McNews Automotive AEM UEGO wideband Ford Racing 39# injectors Autolite 104 copper core plugs Cosworth oil baffle Ford Escape oil cooler All 3 VF Engineering motor mounts Exedy Flywheel Exedy Stage 2 3-puck clutch Quaife ATB LSD 3.82 final drive Suspension Front: Gaz height and dampening adjustable coilovers Suspension Rear: Spax adjustable shocks with F2 coilover conversion Progress 22mm rear sway bar Brakes Front: 2005 280mm discs Brakes Rear: AdvanceTrac rear disc conversion ST170 headlamps Ghia front grill Mk1 Focus RS rear spoiler Modified S&W Racing 4-point rollbar Corbeau Forza seats G-Force 6-point harnesses Steeda Tri-Ax STS Rear relocated battery Sparco battery kill switch with custom 3d printed mounting bezel VDO oil pressure and temperature gauges OMP pedals Sony CDX-GT510 radio
Add your comment
See more
WBygSBEVtRa3KaxWI2mVhcpmPZfe3RWkcuphk1lHUJ48geWgJ7nu5yHY5VtH9RJI
