Purchased on Feb 20, 2016. 1995 M3, 202k miles, came with dealer service records up to 140k. Runs great, drives less so. Needs ball joints, tie rod ends, tires, hood release cables, and a bit of bodywork. Paid $1500, will be built with the $2017 Challenge in mind.
Latest updates
April 03
They were pretty thin but not down to the backplates, so the rotors were still …
April 03
Painted and installed
April 03
A little 220-grit
April 03
Before: duct tape residue, paint missing from kidneys and lower grille.
March 14
I think they look pretty good, but are too wide to package anything but a …
March 13
Scored a staggered C4 Sawblades, 17x8.5F/9.5R.
March 13
Aluminum RF LCA to match the LF . It’s nice to have tight ball joints!
March 13
Out with the old
March 13
Oil and filter change, nothing exciting.
March 13
$9.11 at FLAPS for an exhaust sleeve and 2 clamps. Tightened them down and cut …
March 13
Spent $6.49 at Home Depot on some #14 x 3/4” sheet metal screws and some …
Feb. 29
Different wheels and tires, plus properly torqued wheel bolts, solved the vibration.
Feb. 29
Nothing wrong with guibo or center support bearing.
Feb. 29
Dropped exhaust to inspect driveshaft
Add your comment
Wh1Fe6KiyKtETilJKZW1USTJw5ptcegmZyVnohe9itdSfotOnY5aAcgr79bhGaRN
