Started on April 22 by dangerwillrbnsn
1981 BMW 320i
This car has been my baby since March 2014. I am the second registered owner. The first was a chiropractor from Denver who passed away. The car was in overall extremely clean condition for being 36 years old, although she’s not perfect. The paint was shot, but the body was straight and the interior clean. I found no evidence of rust, so I pulled the trigger and saved it from certain death rotting under a tree here in Colorado. Details: 1981 BMW 320I (s). Alpina replica. Current Modifications: Refreshed 1.8L engine built by me. Also have a forged 2.0 ready to build. Head resurfaced, new valve seats, 3 angle valve job, gasket port matched. New Luk pressure plate with a MIBA ceramic 6-puck clutch and a resurfaced flywheel Transmission got new input and output seals, new guibo, new mount. DIY turbo system. Currently set at 12 psi, but capable of 21 psi with current equipment: Borg Warner kO4s turbocharger. Manifold from sch40 mild, ceramic coated and fully TIG welded and decked flat by a machine shop, then ceramic coated. Generic Tial replica BOV Custom made 2.5” aluminum piping with IAT and BOV flanges TIG welded,and powdercoated white. 18x12x3 Front Mount Intercooler Hand made 3” mandrel bent turbo-back exhaust to a K-tuned turndown style muffler. MEGASQUIRT II Standalone EFI, controlling fuel and spark. Re-built the stock distributor with VW guts, locked the timing. Tune is still rough, but I play with TunerStudio every time she’s driven. It’s a neverending work in progress. E30 318i intake manifold 42# Seamins decka flew matched fuel injectors All necessary MSII sensors, including Coolant Temp sensor, IAT sensor, etc. Dizzy fired hall effect ignition. -Custom built coilover Suspension: Shortened stock strut housings 350/250 eibach springs (very firm, but still comfortable) Bilstien sport MK1 GTI stuts 77 fatter front sway bar rear sway bar (is) -e34 bilstien sport rear shocks 3.91:1 limited slip diff New front LCAs Bavauto antishimmy kit New front bearings New swaybar bushings Ireland Engineering front strut bar New front upper strut mounts Optima Blue Top mounted in the Trunk ESM RS replica 16x8 weels with good BFGoodrich R1 Sport tires 205/40. Rota Alpina replica 15×7 wheels with Khumo Ecsta tires 195/45 New front Volvo/Girling 4 potcalipers / rear cylinders New front vented rotors / rear drums New pads/shoes AlpineWiess paint is 1 year old – it has a few small blemishes, but nothing major. Stored in a heated garage since repaint. -Zero rust! Front bumper delete Euro single Hella H4’s installed Recaro sport black leather and Herringbone seats in gorgeous condition. Hawk HPS front brake pads Oil catch can 16” electronic fan RARE BBS leather steering wheel iS 3-Spoke Steering Wheel Homelink custom installed. Sheetmetal center console VDO boost gauge, oil pressure, oil temp, and battery voltage APSX wideband digital volt meter I suppose all I can say is that it’s very unique… Not another one with the same setup anywhere in the world (so far as I know). Estimated 180hp @ 12psi (current). 230hp @18psi. 250hp+ @ 21psi. The car only weighs 2300lbs, so it SCOOTS.
Add your comment
See more
o8zwlSObyquLYDn9NEq7QiFJKsi6kHW0XlethBjzXeY2OC0d4mi9Xufxtk2LjWB2
