Started on Sept. 25 by icdpride
1986 Volvo 244 DL
1986 Volvo 244dl 4spd M46w/od B230f +t 86 block, installed oil squirters and rods from 93 new rings and bearings Cometic head gasket 530 head with some minor porting work IPD Turbo cam 2.2lh Block mounted distributor Megasquirt 2.0 v3.57 with Mapdaddy 4bar 10’ ms harness from diyautotune.com OBX (ebay) turbo manifold flipped and re welded with braces and extermal wastegate 38mm External wastgate Gt35 (a/r .70) ebay turbo 3” downpipe 3” full mandrel bent 2 pc exhaust with thrush turbo muffler and v-bands Innvoative ls-2 Wideband o2 Large FMIC Walbro intank 450lbh GENSSI Blue Type S Adjustable Fuel pressure Regulator YoshiFab redblock billet TPS sensor adapter 1000cc injectors with resistor pack 2 12” efans Dual core ka aluminum radiator Ebay fender flares 15x10 Steelies with stretched tires
Add your comment
See more
MiaX9cYhRmesUwK6kZetsQdxeMqxuqdNz7iTwkRGboS5MFfpdhGJnak8pDWpFsT8
