Started on Jan. 22 by RoHo
2007 Lotus Exige
Orange Outside HkFever side skirts HkFever front spoiler HkFever rear spoiler Reverie CF side scoops Sector111 rear diffuser ” aluminDIFFUSER” RLS/NCI allen conversion for undertray/diffuser Lotus S240 MoHawk Roof Inside Alitech shifter Reverie CF shift knob Sector 111 shift cables NRG Gen 2.5 quick disconnect OMP steering wheel Sector111 DBW pedals Sector111 Sys 6-pack Schroth ASM belts Safecraft stainless steel fire system Chassis Stainless steel brake lines / Motul 600 fluid Sector111 DS brace rear toe links Innovative Motor mounts. Front and rear. Jack point lift kit Wheels and tires Sector 111 Bullet stud kit Engine compartment Bone stock engine. Never installed bigger injectors, smaller pulley, etc. Coldfire 270 ECU and stock ECU. BOE surge tank In tank fuel pump upgraded to Denso S260 pump. Sector111 Plug-N-Play Fuel Pump Pump rated (280lb/hr vs 150lb/hr stock @ 47psi) Radium catch cans, with dipsticks RLS intercooler RLS CF intercooler shield RLS CF baffled intercooler shroud RLS side intake kit Radium silicone intercooler hoses and t-bolt clamps Sector 111 GPan baffled oil pan RLS/NCI oil lines Factory Lotus Cup air box Exhaust 2bular custom 7x18 GT3 exit exhaust 2bular High flow cat 2bular Catless U-Pipe Battery Odyssey 680 battery Sector 111 Xtender battery cutoff switch RLS/NCI Battery mount C-Tek trickle charger Misc Lotus Sport floor mats JVC 1.5 DIN head unit with back-up camera Hella horns Sector 111 folding front tow hook Sector 111 BBHook2 rear tow hook Penske double adjustable shocks from BWR 550F/800R springs BWR front sway bar track version 949 Racing 6UL 111 wheels via Black Watch Racing 17x9 rear 15.8 lbs with Bridgestone RE-71R tires 255/40R17 15x8 front 12.6 lbs with Bridgestone RE-71R tires 205/50R-15
Add your comment
See more
rtEhUcNJ9fCFcxNChfXOuXk63VnoMMlMsrvKorbKodzOOfmJQmLn1gKyV131wjPc
