Started on June 18 by avandeth
2008 Porsche Cayman S Design Edition (Slightly modified)
Aerocatch Hood Latches (x4) FF1 Black Engine Mount Insert Fab Speed Rear Jack Point Gt3 3rd radiator Wire mesh radiator grills (x6) Racing Rear Vision Mirror RSS Folding Tow hooks (2) Interseries Wing Base Headlight Covers Carbon Fibre Dive-Planes Cayman Rear Flares 987 - Carbon Fiber Grand Am Front Bumper, Splitter, Front Quarter Panels L & R - Carbon Fiber Lexan Side windows with NACA ducts European Cayman Rear Bumper AIM Solo DL /SmartycamHD Peltor Motorsport Intercom - Modified for IMSA headset Racetrac 4 Helmet Boom IMSA 10 Bank Fuse Panel Master Cut-off switch Odyssey 680 Battery, Rennline mount and Terminals Aim SmartyCam GP HD Bullet Camera and mounts Aim Channel Expansion Podium Connect 160F Low Temperature Thermostat Accusump 3QT w/ EPC Valve 35-40 PSI LN Engineering - Spin-on Oil Filter Adapter for MY97-08 Cayman FilterMAG SS300 for use with our Spin On Filter Adapter Mantis 2 Q Deep Sump Kit TRS Porsche 4″ Crankshaft Under Drive Pulley Kit CAE Gearshift Cable Kit for Porsche Cayman & Boxster Borla Exhaust EVOMS V-Flow System EVOMS RS350 ECU Flash 3.4L Competition Plenum with 82mm GT3 Throttle Body TRS Direct Oil Feed for IMS Light Weight Flywheel Sach ZF Sprung Clutch Plate CAE Ultra Shifter Porsche Motorsports AOS and vent lines WaveTrac Automatic Torque Biasing Differential Porsche 987/996/997 NRG Steering Wheel Short Hub Adapter Black NRG Hexagonal Style Black Ring with Horn Button MPI Cupped Steering Wheel Welded Roll cage and SPA Fire Suppression System OMP HTE-R XL Racing Seats (x2) Schroth Profi II Black 6pt Harness Belts Rennline Track Mats - Full Race Rennline Aluminum Pedal Set - 4 piece Brey-Krause - Harness & Mounts & risers Shift Risers FF1 Custom Shift Knob Powerwerx Panel Mount Dual USB 4.2A Device Charger for 12/24V Systems Carbon Fibre Switch Panel Cool Shirt System Nerf Bars front and Rear Longacre 22530 17 Inch Wide Angle Mirror Kit, Short Brackets Longacre 22570 Helmet Hook, Clamp On, For 1-3/4 Inch Roll Bar Safecraft Restraint Systems Left/Right Kevlar Head Net Rennline T=Flat 6 inch Tow hooks ERP Pro Series Lower Control Arm Kit Front ERP Pro Series Lower Control Arm Kit Rear Tractive DDA – RTx PLUS Package Pagid Yellow Pads GT3 Brake Cooling Ducts DSC Controller and 3D Accelerometer Girodisc race rotors Front and Back Rennline Front tower Strut brace Rennline Rear Sub Frame Stabilizer and Tie downs front and rear TPC Stage 1 Sway Bars and drop links Toe Control Arm (ea), Motorsport Style (2) with L Boot option Locking Plate Kit, For Adjustable Toe Link (2) Spacers 4 Wheel Bearings CCW C10, 9” and 11” Hoosier R7s P315/30ZR18 91W, P245/40ZR18 91W
Add your comment
See more
9CRAi0YxC9pSsEjszhJlHq1ncloxQ3UFN5qqELZUHBtFGDqPnoLS7O4pzfapv210
