Started on Aug. 6 by captainawesome
2013 None FR-S
Daily driver/CSP autocross/HPDE 2016 motor/trans. OFTv1 with canned e85 tune. Tsudo catless UEL header/up pipe. Hooker Blackheart “race-only” front pipe. KW V3 Coilovers. Enkei NT03+M Wheels 18x9.5 +40MM. Falken Azenis RT615K+ 235/40/18. Raceseng Cascam Plates. GTSpec Front Strut Tower Brace. Eibach Anti-Roll Kit. Goodridge Stainless Steel Brake Lines. EBC Yellowstuff Brake Pads. DBA T3 Rotors. Grimmspeed Master Cylinder Brace. Whiteline Adjustable Toe Arms (Rear). SPC Adjustable Lower Control Arms (Rear) w/ Toe Kit. Whiteline Adjustable End Links. Perrin Steering Rack Lock. Whiteline Lower Control Arm Inner Bushing (Rear). Whiteline Rear Trailing Arm Bushing (Front, Lower). Whiteline Steering Rack & Pinion Mounts. Whiteline Control Arm Inner Bushing (Front). Whiteline Positive Traction Kit. Whiteline Upper Control Arm Bushing (Rear). SPC Camber Bolt Kit (Front). Whiteline Roll Center / Bump Steer Kit (Ball Joints, Tie Rod Ends). Whiteline Anti-Dive Caster Kit. Perrin and Whiteline Bushing Combo. Whiteline Support Outrigger Insert. Downforce Carbon Fiber Front Lip. Beat-Sonic FDA43 Shark Fin Antenna. OLM Vision LED Fog Light Kit. Winjet JDM Headlights (Black). Morimoto Headlight Elite HID System. Spyder V1 Tail Lights (Chrome with Red Housing). Carsmo Design Rear Duckbill Trunk Spoiler. Velox Throttle Pedal Spacer Kit. Cusco Sports Accelerator Pedal. Sparco Champion Steering Wheel. NRG Generation 2 Quick Release Steering Wheel Adapter. NRG Short Hub. JPM Coachworks Alcantara interior trim. Toyota black interior trim swap. Toyota exterior badges.
Add your comment
See more
CNgUJapBYs1wnrtUHyhctlP1p7zUdfijw77VRpNl3Bo9QE8TSVvADROFzhOKYEhY
