Started on Aug. 7 by Hydro
2006 Subaru USDM Impreza WRX STI (GD)
Car’s Name: Otis Engine: Tuned by Airboy GroupA lightened Alternator Pulley GroupA lightened Crank Pulley GroupA Pitch Mount K&N Typhoon APS 3” TBE APSWRX-HOE/R1 Coob SS Heat Shield WRX_RA Radiator Shroud with Hydro Engraved on it… Gonna get one with OTIS on it soon! Mobil 1 5W30 Synthetic Genuine Subaru Oil Filter Transmission: Cobb Adjustable Short-Throw Shifter Kartboy Shifter Bushings - Front and Rear Lathe Werks Hybrid STI Piston: Red alcantara w/ Black stitching; OTIS Engraved on top Lathe Werks STi Shifter Reverse Ring & Boot Collar: Stainless Steel Reverse Ring and Pins/Copolymer Boot Collar (WHITE) and screws Motul 300 75W90 Gear Oil (Front and Rear Diff.) May 14th, 2009 — 35,600 miles: AMSOil Severe 75W90 Gear Lube in the tranny, front Brakes: PowerSlot Front / Rear Slotted Rotors Hawks Performance HP+ Goodridge Stainless Steel Braided Brake Lines Motul RBF600 Wheels: Gold OEM BBS 17’s Silver OEM BBS 17’s Suspension and Bushings: Updated - May 13, 2009 Whiteline Com C Upper Strut Mounts - Front (P/N: KCA335) Whiteline Front Upper Strut Tower Brace (P/N: KSB599) Whiteline Rear Upper Strut Tower Brace (P/N: KSB511) Whiteline Front Adjustable Sway Bar - 24mm (P/N: BSF36XZ) Whiteline Rear Adjustable Sway Bar - 22mm (P/N: BSR37Z) GroupA Front Endlinks (P/N: GA-010-A) GroupA Rear Endlinks (P/N: GA-010-A) Whiteline Sport Anti-Lift Kit (P/N: Sport KCA359) Whiteline Front Control Arm Bushings Kit - Lower Inner Front (P/N: W52837) Whiteline Rear Control Arm Bushings Kit (P/N: W61382) Whiteline Steering Rack Bushing Kit (P/N: KSR306) Whiteline Front Roll-Center Adjustment Kit (P/N: KCA313) SPC Camber Bolts - 14mm Front and Rear (P/N: 14mm Cam) GroupA Subframe Locking Bolts (P/N: SUB-LOCK) Kartboy Rear Diff Support Bushings (P/N: KB-003D1-COM) Kartboy Subframe Outrigger Bushings (P/N: KB-003-DIFF) Group N Engine Mounts (P/N: GroupN Mount) Group N STI 6 Speed Transmission Mount (P/N: D1010FE000) Kartboy Transmission Crossmember Bushing Kit (P/N: KB-025) Tires: Competition: Nitto NT-01 245/45/R17 Street: Falken FK-452 235/45/R17 Winter: Hankook W404 225/40/R17
Add your comment
See more
Y3Nh7XmQ8WQY6i0UwTTddlEXFWMYqyZtaQCvoj07DBRpELJjBJyva6ibzglzqvxF
