Was my daily driver, but as of late i’ve been turning it into a HPDE car. Mods are: Engine: Vengeance ported FAST 102mm intake manifold, FAST 102mm throttle body, FAST 36LB injectors, FAST LS2 fuel rail, Texas Speed 100mm MAF, Racetronix Fuel pump and harness, Volant CAI, SLP Loudmouth 2, LTs, ORY, LS6 high volume oil pump, LS2 timing chain, LS6 Yellow springs, Thunder Racing 7.425 Hardened pushrods, ASA cam, Turn One power steering pump, Powerbond 25% underdrive pulley, Suspension/Chassis: Fays-2 Watts Link, UMI Road course k-member, UMI Adjustable lower front control arms w/ solid bushings, Global West upper control arms, UMI 3 Point Subframe connectors, UMI tubular rear lower control arms and relocation brackets, UMI Adjustable torque arm, Poly torque arm mount, Spohn tunnel brace, Brembo 6 Piston Cts-V front calipers and 14 inch rotors, Baer Tracker bump steer tie rod end kit, Koni single adjustable shocks/rear double adjustable shocks/front, Strano springs, Strano front sway bar and adjustable rear sway bar, Hotchkis Strut tower brace, C6 Z06 10.5” wheels with BFG R1’s for track days, Quantum Motorsports Brake Spindle Ducts, Goodridge Stainless Steel brake lines, SLP line lock kit, Prothane engine & tranny mounts, ARP wheel studs Drivetrain: Six Speeds Inc stage 2A kit, Spec stage 1 599ft/lb clutch, Fidanza Aluminum flywheel, Tick performance clutch speedbleeder line, B&M short shifter, Skip shift eliminator, Hurst Shifter Knob, Ram adjustble master cylinder, Moser forged axles, Auburn Racers differential, Richmond 3.42 gears,
I’m doing 2 days at Watkins Glen next weekend so I had to take care …
I was going to change valve stem seals in the car but when I put …
Getting ready for this seasons HPDE’s. I’m trying to get rid of any problems early …
Just added a set of Recaro Pole Positions along with Schroth Profi III Hans Harnesses. …
