Started on Sept. 6 by dupont
1972 Maserati Indy
i have a 1972 Maserati Indy 4.9 it is 1 of 300 made. it needs to be assembled but have over $25000 in new parts. every part needed to assemble this car is new or restored so it ready to be put together. Also it had a body off restoration. everything needs to be put together including the 4.9 liter v8 which has Quad overhead cams(4)and 4 two barrel Weber carbs. over 50k invested . The engine has been completely machined with new valves, heat baked paint and balanced cam. The body was professionally restored with three coat’s of primer and undercoating (no bondo) every part is either new or sandblasted and painted. I am curious how much the car is worth as is? Finished? how much the engine is worth? any info is helpful.
Add your comment
See more
n7kkxBJTg4GQsCe3MtxNbBVgc94tcWXFPxLT3vIUggNIcj2FRQ60NSvAJ3DJu85C
