Started on Sept. 24 by HamfistRacing
1993 Mazda RX-7 R1
Owner: Jake Namer Race Team: HamfistRacing.com Class Eligibility: * SCCA SOLO - A Street Prepared * Redline Time Attack - Street RWD * NASA TT - Unlimited * MotorsportsNE - Unlimited Handling Modifications: * Koni Yellow / Ground Control Coilovers (600 lbs/in Front & Rear) * Racing Beat Front Sway Bar * Mazdatrix Front Adjustable Endlinks * Widefoot Front Sway Bar Support Wheels & Tires: * 16"x8" OEM * 245/45/16 Toyo R888 * 17"x9" Rota DPT * 245/40/17 Dunlop Z1 Star Spec * 17"x9" Rota DPT * 295/35/17 Hoosier A6 Braking Modifications: * Hawk HP+ Pads * Goodridge Stainless Steel Brakelines Power Modifications: * Apexi Power FC ECU * 850cc Injectors * Nippondenso 280lbs/hr Fuel Pump * Turbo-Back 3" Exhaust * Magnaflow 3" High-Flow Catalytic Converter (Metallic Substrate) * Racing Beat Twin Tips Cat-Back * Apexi Ram Air Intakes * ARC Stock Mount Intercooler * Coolingmist Water/Alcohol Injection Exterior Modifications: * 35% Window Tints Interior Modifications: * Escort Passport 8500 X50 Radar Detector * Autometer Boost and Water Temperature Gauges Other Modifications & Maintenance: * Deka Lightweight Battery 6 lbs * Koyo Radiator * Castrol GTX 10w-30 * Silkolene Trans Fluid 75W-90 * ATE Super Blue Racing Brakefluid Wishlist for SSM (Super Street Modified) Build: * A-Spec Tuning GT30R (or GT35R) Single Turbo Kit * Rotary Extreme Vmount Intercooler Kit * Exedy Stage 1 Clutch Kit * OS Super Lock LSD * Mazda RX-8 4.77 Ring and Pinion * Mazdaspeed Differential Mount Bushings * Mazdaspeed Vented Hood * Recaro Speed Avus (Color: black / white seam)
Add your comment
See more
eYNUPudRBbG3BcItDGsBSX7iZde4ndXElj4JwSE1FmOzOGOUp6S2dnxtU6nvZOZH
