Maximum Attack! Mod2WD RallyCross Neon. 1998 Dodge Neon SOHC Coupe prepared for SCCA Rally Modified 2WD class. HotBits DT1 gravel rally suspension 55Nm/30Nm coils. 6.5” ground clearance 20mm front bar, 16mm rear. Custom end-links. Hankook R201 gravel rally tires A/C and Interior removed, sound deadening removed 2250 lbs. dry weight Stock SOHC 2.0L top & bottom over-bored TB, MPP PCM 3.94 trans, limited slip 16:1 “Firm Feel” steering rack pimpin’ rally-bling Sparco wheel widened front track Still a work in progress…
You'll need to log in to post. Log in
