Started on Oct. 29 by metalmaster1766
1966 Volkswagen Bug
Modified 66 VW Bug with small block Ford C4 trans, built using almost all used parts from cars and trucks from the past, except for the frame which uses a 1992 s10 truck front suspension cut off and attached to a custom built 2” by 4” tube frame. Rear axle is what was in the 92 s10 truck using a custom 4 link of my own design and coil over shocks. All sheet metal used to fill in the inside, floor board, rear deck behind front seats and firewall areall from s10 Blazers of truck hoods and roofs. only sheet metal from another car is the dash which has been moved back 6 inches and filled in the gaps with the hood from an 81 Mustang which is where the engine & trans came from.
Add your comment
See more
56vYdWzE1DzcKi8dPG5vlkbuvqRCsljgzTv0b6HcaKDp6uQjBvdbPicnD3GglH76
