My first Suby and I’m hooked forever! The car has been modded for autocrossing from almost day 1, but is still a great DD. Mod list- Engine: • Kartboy LW pulley • Grounding kit • Kingsborne ignition wires • 3” PDM intake/ 3” elbow grafted into OE airbox • Modified Crawford air/oil separator • Borla Gen IV header • Random Tech cat-pipe • Kartboy exhaust hangers • Custom cat-back using 2-1/4” pipe and two Magnaflow mufflers • Group N pitch mount • Group N engine mounts Fluids: • Redline 5W30 (engine) • Redline D4 ATF (power steering) • Swepco 201 80W90 (transmission) • Redline 75W90 (rear diff) • Castrol Synthetic LMA (clutch and brake system) • Subaru Super-coolant and Redline Water wetter (cooling system) Drivetrain: • Kartboy short-throw shifter • TIC shifter lever bushings • Cobb shifter bushings • Kartboy rear support shifter bushing • Kartboy crossmember bushings • Group N transmission mount • Whiteline differential bushing kit (clunk stopper) Interior: • Subaru 6 disc in-dash changer • Kicker replacement door speakers (huge sound quality improvement) • Scanguage II • Lathewerks STI style shifter extension and black teardrop copolymer STI shift knob • WRX gas pedal, matching dead pedal from Mach V • SRP aluminum grid style clutch and brake pedal • Red S202 hazard switch Exterior: • S202 replica wing • (autocross) black Rota Tarmac wheels/ Dunlop Direzza Z1 Star Specs 235/45R17 tires • (street) stock wheels painted black/ Conti Extreme Contact 225/50R16 tires • McGard Spline drive lugnuts • cleared headlights • 3M clear bra Suspension: • Tokico D-specs • RCE Black springs • Cusco front camber plates • Cusco front endlinks • Whiteline 22mm FSB • White Line 22-24-26mm RSB • Mr. Joshes rear endlinks • Group N rear tophats Brakes: • WRX/H6 rotor upgrade • Goodridge stainless lines • Stoptech street compound pads
