Started on March 3 by 1987buickgn
1999 Ford Crown Vic
I have a 1999 Ford Crown Vic. It does have the police package. It still have the spot light (which works), the police center console, and the cage in the back. The instrument cluster is showing 195,XXX miles on it BUT the engine and transmission was replaced at 147,382 miles with factory ford remans. The car was taken out of service with 187,200 miles on it. Sence i have owned it I have put alot of time and money in to it. I have records of what i replaced and the mileage when it was replaced. THIS IS A TRUE ONE OF A KIND CAR AROUND THIS AREA. As you can tell for the photos on this ad. I have done the fallowing: intake manofold, spark plugs, tie rod ends (inters and outers, on both sides), coolant flush, transmission filter, fuel filter, upper and lower ball joints, alignment, rebuild rear axle with a limited slip differential, battery, valve cover gaskets, AC compressor, receiver/dryer and office tube, sway bar links, all o2 sensors, master cylinder, and much much more. Since i have owned this car it has had nothing but full synthetic motor oil in it. The oil has been changed before or right at 3,000. I dont beleave in going over 3,000 miles. Asking price is $6,000 or best offer……May consider trade for a toyota, lexus, or a cab in a half/ crew cab full size truck
Add your comment
See more
er5zz8VDD6UgZwpjKPSsTE8z9wTJjGOYeIWYSDx5jAOA9OZda4Gbn4ERGzG1lMTF
