Started on May 11 by vegavairbob
1971 Chevrolet Vega Panel Express
1971 CHEVROLET VEGA PANEL EXPRESS Mediterrian Blue (exclusive 1971-‘72 Vega color) Black interior trim 1 of 7800 Panels of 277,700 Vega production for ‘71 Stock - 49K miles - Original Powertrain & Paint/Trim Codes Specs 140 CID aluminum block I4 90 hp Rochester 1 barrel Carb 3 speed Manual Transmission 2.53 Axle (std ratio w 3-speed) Front Disc / Rear Drum Brakes Curb Weight - 2230 140 CID 1bbl OHC I-4 Aluminum Cylinder Block / Cast-Iron Cylinder Head Single Overhead Cam Manufacturer Chevrolet Bore × stroke 3.5 in × 3.62 in Cylinders Inline-4 Displacement 2.3 litre 2294 cc 139.988 cu Fuel system 1 1bbl Rochester carb Maximum power 90 HP @ 4800 rpm Maximum torque 121 Ft / Lbs@ 2800-3200 rpm Main bearings 5 Coolant Water Wheelbase 97 in Track front 55.1 in rear 54.1 in Length 169.7 in Width 65.4 in Ground clearance 4.8 in Fuel capacity 11.1 US Gal 0-60 - 12.5 sec. Top speed - 95 mph Fuel Economy - 30 mpg *Motor Trend August 1970 Factory Options Auxilary Seat (passenger) Tinted glass AM Pushbutton Radio A78x13 Bias-Belted Tires Right-Hand Mirror - accessory Mats (GM direct fit) black - accessory Mods 175/80R13 WSW Radial Tires (5) (original A78x13 WSW tires in storage) 1971 Chevrolet Vega- Motor Trend 1971 Car of the Year Car and Driver 1971 Readers Poll - Best Economy Sedan:
Add your comment
See more
TKVuQUQvU1YosDlKWRgtEhev6CP4plCp0L1d1qSaDNzeDx72SoXYwpU5lPo4Lot5
