Started on May 18 by trackrunna95
1994 Acura Integra LS
Just a track day car and all around fun driving car Suspension: Eibach Pro-kit springs, KYB GR-2 struts, Energy Suspension bushings, Skunk2 Pro-plus front camber kit, Wicked Tuning rear camber bolts, Blox 21mm rear sway bar, Blox rear lower control arms, ASR subframe brace, Godspeed rear cross brace, AR front strut bar Power: Crower steel valves, Crower dual valve springs and titanium retainers, Supertech bronze valve guides, Eagle forged crankshaft, Weapon R intake, custom welded cat-back Burnout exhaust, knock-off DC 4-2-1 header Transmission: Type R transmission, Exedy Stage 2 clutch, Fidanza flywheel, Omni-Power clutch master cylinder Brakes: Stoptech steel brake lines, Brembo slotted rotors, EBC Redstuff pads Wheels: 15” steelies all around, Bridgestone Potenza RE11s, F 225/45R15, R 205/50R15 Interior: MOMO 350mm suede steering wheel, Skunk2 short shifter and knob, Luffy stuffed toy holding a “Safety Driving!” sign
Add your comment
See more
VYm1xLd6R1f2DoztE3ogC9bqKzQRH6nMm9AnYMdliO1nEVHc8nemIpBQTs9FoVDq
