Started on May 29 by misnblu
1997 Chevrolet Cavalier Z24
MODIFICATIONS Engine: * HPTuners * Custom true cold air intake * K&N E-1006 air filter * Stock upper engine mount w/ poly insert * RKSport lower engine mount * Pacesetter 4 - 1 Ceramic Coat long tube header * Atomic 2.5 full exhaust sytem w/2.5 piping * Cat delete * Magnaflow TL Turbo muffler * RKS Billet aluminum underdrive pulley * Autotransinterceptor transmission shift kit for the 4t40e * RSM Racing 60.9mm throttlebody * RSMRacing bored intake manifold * Accel adjustable fuel pressure regulator * VDO 1.5 inch fuel pressure gauge * Earls stainless -4AN braided fuel line * Custom DIS ignition relocation * MSD 8224 coil packs * MSD DIS-2 6211 ignition system * Accele ProStock 8mm wires * 4 wire O2 sensor conversion * Weight reduction * MRZPerformance billet radiator and brake reservoir caps * Merceded Benz Behr oil cooler * Permacool oil sandwich adaptor * Motorcraft FL-1A oil filter running 6.0 quarts of oil * NHRA/ IHRA legal battery relocation * Braille Racing battery * ABS delete with custom Earls plumbing * Suspension/Wheels/Brakes: * GM front strut tower brace w/ 2 firewall attachments * Custom front strut support brace * 1999 Alero Aluminum control arms-modified to fit * Eibach Prokit springs * KYB struts * Prothane control arm bushings * Eibach 22mm rear swaybar * Eibach 26mm front swaybar * TTR K-brace * RKS rear strut tower bar * Custom trunk bar * Custom triangulated 6 point trunk bracing * Custom 4 point chassis V-brace * Earls front and rear stainless brake lines * Wilwood front big brake kit * Rota Boost 17x8 inch gunmetal rims * McGaurd Spline lug nuts w/ red top * LZM rear twist beam poly bushings * Custom axle work for weight reduction * Custom rear tie bar * Neon rear disc swap using 2004 SRT4 components * EBC redstuff rear disc pads * EBC cnc slotted Neon SRT4 rotors * Overkill Engineering Motorsports front camber plates * Overkill Engineering Overkill rear pillow ball mounts * Interior: * Grant Challenger black w/ red trim 13.5 inch steering wheel * ProForm shift light w/ blue lens * Custom pushbutton start switch w/ safety cover * Billet tilt lever (thanks to Cavy2Envy) * Fan bypass override switch * TCC control switch for torque lockup control * Shift knob from '99 Grand Am GT w/ modified integrated drl/ traction switch * Customized triple gauge pod with SRT4 vacuum-boost gauge/ AeroForceTech Scan gauge/ and AEM Uego wideband * AutoMeter oil pressure gauge mounted on dash * AutoMeter fuel pressure gauge mounted on dash * Custom air intake temperature sensor w/lcd readout * R-1 Racing Sports aluminum pedals * R-1 Racing Sports seats w/red/ black inserts and custom made seat brackets * Manual shift boot from stick Cavy * 3 black lights * 2 under dash blue neons * Custom mounted terminal blocks including 12v turn on/ constant power/ and ground * ACC carpet black pile carpet * Floor bar (room bar) brace * Custom rear seat delete * Custom 4 point B-pillar brace * Non spoiler 3rd brake light rear deck swap * Fire extinguisher Exterior: * Shaved factory badges * Erebuni carbon fiber extractor hood * JSP carbon fiber trunk from DarkStars * MOMO stainless steel hood pins * 2.2 front bumper swap * RKS front lip * RKS 'Import Fighter' side skirts * 2500K Nokya headlights * Shaved/ polished headlights * Amber bumper lens * Pontiac Sunfire tail/ trunk assembly * Toyota 2.4Z badging * Shortened antenna * Custom l.e.d. back up lights Audio: * Pioneer TS-6944 rear 6x9's * Pioneer TS-T10 tweeters * Pioneer TS-T15 tweeters * Custom built passive crossover network for front stage Future: * Steigmeier built M45 supercharger(already have) * Devils Own meth injection kit * Much more to come
Add your comment
See more
i3ir3qtWsNloq2V1F4EnJ6maiaVwApqPtTDQan5KUcIIeda9LGogmr4Xa9f6UIIM
