K20A swap from DC5 Integra Type R ASP 4-1 header 2.5” Hi-flow cat 2.25” DC Sports cat-back exhaust RBC intake manifold Kpro chipped ECU Hasport EKK2 mounts Hybrid Racing no-cut shifter box DC2 Integra front subframe, lower control arms, 22mm sway bar and steering rack SW20 MR2 Hydro-electric P/S pump Hybrid Racing full sized aluminum radiator HR Tuning Tunerview II info center Autometer Elite series programmable oil pressure gauge Innovate MTX-L wideband 205/50/15 RE11 on 15x7 +35 wheels Koni Yellows Ground Control coilover sleeves with 380F/430R rates ASR rear subframe brace 23mm JDM Integra Type R rear sway bar with Function7 adjustable end links Function7 rear lower control arms Legend 2-piston calipers with modified brackets Hawk HPS pads Re-drilled 11” Prelude rotors 98-01 Integra 1” Brake master cylinder
