Started on July 7 by RyneatSchwartz
1965 Pontiac Tempest
13
1965 Pontiac Tempest Schwartz Modified Body Measurements Wheelbase (in) 115.00 Height (in) 53.50 Width (in) 73.30 Length (in) 206.10 Curb Weight (lbs) 3,250.00 Fuel capacity (gal) 12.0 Engine Details Engine Type OHV Engine Code LS3 Cylinder Arrangement V8 Bore x Stroke (in) 4.06 x 3.63 Displacement (CID) 384 / 6.16 Aspiration Natural Construction (Block/Heads) Aluminum/Aluminum Sump LS7 Dry Compression Ratio 11.0:1 Fuel System Type Injected Max Horsepower (hp @ RPM) 500 NA / 650 on nitrous Max Torque (ft/lb @ RPM) 435 NA / 580 on nitrous Redline RPM 7,000 Power to Weight Ratio 0.1833 Chassis Details Front Suspension Type Coil-Overs Rear Suspension Type Coil-Overs Front Wheel Size (in) 18 x 9.5 Rear Wheel Size (in) 18 x 13 Front Tire Size 275/35 Rear Tire Size 335 / 30 Front Brake Size (in) 14.0 Rear Brake Size (in) 14.0 Transmission Details Gears 6 Forward 1 Reverse Final Drive Ratio 3.23:1 First Gear Ratio 2.97:1 Second Gear Ratio 2.07:1 Third Gear Ratio 1.43:1 Fourth Gear Ratio 1.00:1 Fifth Gear Ratio 0.80:1 Sixth Gear Ratio 0.62:1 Reverse 3.28:1
Add your comment
See more
EP2u9NnSf6uSbScKNC6NVA27gze9zGjVXrt21MrbGHvUCEubg9DVk5qnpVNSrWnC
